Biblob
- Joined
- Sep 13, 2018
- Messages
- 686
- Likes
- 692
That makes sense yeah!Thank you!
The side ports are straight (if that is what you are referring to), as @CinamonRolls says, the entire enclosure is tilted.
With regards to the front baffle vents on the Manta, they are actually there to trick the coax into "seeing" a more narrow baffle and improve off-axis response. This is not needed on this speaker since the driver is almost as wide as the baffle, and the baffle itself is also more narrow than the Manta.
I'm actually referring to the inside of the box. You don't use a straight 'plate'/baffle where the backwave reflects off from. You use a more slanted/trapezoid shape inside.
Can you explain how this works?
