I'm not sure if I agree that the effect has been greatly exaggerated, I guess it depends on if we're talking about measurable effects or audible ones. I've not been a big believer in the "clearly audible" camp when it comes to these things. Could be, I don't know.I guess it would be interesting to build a version of the Manta without all the holes in it, so a completely traditional enclosure, and measure it in an anechoic chamber, but I never did that. And even the initial prototype had cardiod slots in the upper chamber so I don't even have rudimentary measurements of such an enclosure. But my theory is that the cardioid system makes for a somewhat more chaotic off-axis response. At least the way I ended up doing this. The Dutch&Dutch on the other hand is pretty clean.
The SBS.1 is a sealed speaker with a quite narrow baffle, so it's much easier to make "clean" from a measurement standpoint. But the fact remains that while the SBS looks cleaner and has a higher preference score, the Manta is clearly superior from a subjective listening perspective. Don't get me wrong, the SBS.1 sounds great too, but it's not the same.
With regards to rounded/chamfered edges my experience is that the effect of this has been greatly exaggerated. As an example to support it with other than my opinion; Look at for instance the clearly engineer driven 20,000€ Kef Reference 5. A great speaker in most respects. Not very rounded edges.
In terms of measurements, my DIY JBL M2's have sharp edges instead of the chamfered edge on the original and at far off-axis it's clearly measurable diffraction artifacts compared the original.
KEF have the "shadow flare" to fight the diffraction effect. It seems to work well.
Yessir! In my opinion this is the area that separates normal sound from truly spectacular sound. Getting the bass/lower mids right is the greatest struggle, and that's the area where clever design of speakers, sane placement of arse, shoutboxes and effective acoustical treatment have the greatest effect.To clarify: Are you implying that the rising tendency from 150-400hz is undesirable?
It's where line sources, CBTs, infinity baffles, cardioide and horns have most of their advantages imo.
Note that I'm not arguing to tune the speaker in such a way as to make the measured in-room response look better, that will sound horrible! I'm simply implying that aiming for good in-room performance as well as anechoic performance is worth the effort.
I mentioned a woofer behind the speaker just because I figured the placement close to the front wall and floor would perhaps be a worthwhile trade-off.
If the Hypex amp can do FIR filters, it could even be used for cardioide in the higher range where the cancellation with the front woofer could be a problem without changing the timing/phase. This is how Kii does it.
Just throwing out ideas until somebody ignores me.
First of all, the Manta is truly fascinating! It's a balls to the walls attack on everything that sucks with regular speakers and how they work in the room.In Mantas defense I'd also like to point out that everything is relative, and also that the graphs at spinorama.org is pretty squished up, so they don't do anyone any favors.
There's not actually a lot of "wiggles" to fix. On-axis is +/-2.5dB, and if you give the graphs a bit more space, it doesn't look half bad off-axis either, including the famed 1-2khz area.(0-30-60 from the Klippel measurements below):
Separated bassboxes, high capacity, cardioide, coax mid/tweet and if I'm not mistaken, with phase linear crossover filter?
Compared to the constant directivity design of JBL M2 your speaker looks exceptional on that graph. Well done!
Secondly, in terms of diffraction and wiggles, it's really hard to tell the effect of it without testing. I would guess the difference between 30 degree and 60 degree plot could be diffraction artifacts. At least in my own speakers it's beyond 45 degrees it really starts to show, and there it's around 8 khz it really starts to peak. How that would look in a complete Klippel NFS I wouldn't know. I have been thinking of doing outside measurements for a few years to find out how bad it really is compared to the original. But I'm afraid I won't like the speakers no more
