- BL2/ReBL2/Re tells you “how loud it can get per watt.”
- BLBL tells you “how accurately the cone tracks the signal.”
- Both metrics matter—but for different goals.
- BL is about control.
- BL2/ReBL2/Re is about raw power.
- Both metrics matter—but their importance depends on the application.
Is this response an AI-generated cut-and-paste? If so, PLEASE identify it as such.
Do you know what happens to BL when the voice coil resistance is changed?
If you use the exact same motor and replace an 8-ohm voice coil with a 16-ohm voice coil, the BL is INCREASED by a factor of the square root of two. Or if you replace the 8-ohm voice coil with a 4-ohm voice coil, the BL is REDUCED by a factor of the square root of two.
In neither case has the actual motor strength changed! So if you ONLY look at BL, you would think the 16-ohm woofer's motor is TWICE as strong as the 4-ohm woofer's motor. But that would be COMPLETELY WRONG.
THAT is why you have to do the extra math to calculate BL^2/Re, IF you want to do an apples-to-apples comparison of different woofers.
