Have you considered a wall mount @sigbergaudio? It would look good floating up there, slightly downward pointing. I also wonder how the cardioid effect would react to the rear wall...
that husky upper body almost begs to be a floor-stander. you should offer a high excursion 12" sub for it to sit on
I've got heaps of stands. I should photograph some of the ones that may suit your speaker. Like you say, a stand can make or break the aesthetic appeal of a speaker/stand combo.
Target from the UK made a fantastic range of stands over the years. Some of Jamo's stand were lovely, as were many of the Japanese home market Yamaha, Onkyo and Sony stands.
How were they received?We showcased the prototype at a Norwegian hifishow this weekend, here's a few pics
Is that Anti-Mode X4?We showcased the prototype at a Norwegian hifishow this weekend, here's a few pics
Looks good! Personally, I would boost the 1-2 kHz by 1.5 dB.The next revision of the cabinet is delayed further, I'm probably lucky if it arrives before xmas.. So until then I'll nudge the response of this further. Based on the sound at the recent hifi show I concluded that we may need a sliiight increase in the top end, especially given the fact that the listener is off-axis. Smoothed out the response between 1-2khz a bit as well when I was at it.
New (blue) and old response at 15 degrees off-axis (showing from 400hz with 1/12 smoothing as the measurement is done indoors):
New 15deg by itself:
I agree for a slight dip in the 2.5-4 kHz region; but also a slightly higher relative energy 1-2 kHz vs 2-4 kHz. In often can hear that many speakers in stereo setups have a bit too low energy in 1-2 kHz vs 2-4 kHz. This can sound a bit hard and edgy on female voices and tenors.Thanks! We tune our speakers however slightly recessed in the 1-4khz area to make it sound better all round across a wide area of genres, and reduce the risk of songs sounding fatiguing or harsh. The Manta is overall pretty flat, the SBS is slightly more recessed actually.
That being said, the beauty of active, DSP enabled speakers like these is that as a consumer you have direct access to an advanced 9 band EQ (both PEQ and shelf filters), so you are free to adjust to your taste.
Yes that looks really fine!Better perhaps? (blue) - will give it a listen for a couple of weeks but sounds promising (still 15deg off axis, which is typical listening axis)
