A new option is now available for the Inkognito. In addition to (or instead of) the wall mount, you can now get a pair of stylish and clever feet for vertical placement. We currently have a bracket system that is mounted to the subwoofer with bolts for vertical placement, but it is both somewhat cumbersome to install and isn't super pretty. These will be phased out and replaced by this optional add-on. The subwoofer can of course be installed vertically without feet as well, but then one should at least put something under it to prevent scratches.
The new feet stabilize the subwoofer better, making it less likely to tip over even when pushed. They also match the color of the sub (black or white respectively).
The feet fit securely to the subwoofer without any hardware or tools. Just drop the subwoofer gently onto the feet, and they will stay in place, even if you lift the subwoofer.
The soft surface covering both the inside and bottom of the feet ensures no damage to either sub or floor, and also absorbs vibration.
