Love the form factor!
Something like this may be the easiest to construct, but still largely hide the amp: Having the amp on the back (same side as driver, so facing the wall), but all the way to one side and recessed 1-2cm so the controls and cables are still accessible from the side without taking the subwoofer down from the wall:
Out of interest - is there a need to protect the amp module in an active sub from vibrations etc caused by the operation of the sub at higher volume? How does that work - e.g. some sort of foam base under the module, analogous to what active studio monitors on stands use? I’ve always wondered if that’s an issue or not
This looks promising! As a suggestion, you may want to aim to exceed the cea-2010 values for common subs (like cough SVS) to give people an idea of what to expect. If your designs have the same the sound quality but higher waf, it would seem like a no brainer purchase for the average consumer.
Btw what is the internal volume of your 12" enclosure? (or what are the rough dimensions?)
The aim of this product is not to compete with SPL for home cinema setups, and it's more or less impossible given the form factor. The typical SVS subwoofer is 2-4 times the size. I would argue that these subwoofers have better sound quality than many competing brands (no names mentioned), but not the same SPL capability. The component cost (Scan-Speak and Hypex) and quality is way higher and the margins lower than most of the subwoofers you will find out there.
Can this be placed on its side vertically without wall mounting?
Thanks!In theory yes, but it's not explicitly designed to (there's no feet/mount for feet on the side). So it won't fall over by itself, but it's not super stable in that position, so if you have kids or pets etc that could stumble into it, it wouldn' t be ideal. So I would recommend using the wall mount to secure it to the wall at the floor level.
We could also easily build a custom version with feet mounts without any addition to the price, we did this on one of our prototypes to test this option. We could also optionally get custom built extenders to the feet, as it would need to have steel bars that extend out to the side (similar to what some speakers have) for the feet for it to become very stable. That would cost a bit extra. This is also something you could buy from a third party. The feet mounts are standard M8 inserts.
If you would like to share some specifics on your use case (how/where you'd like to place it), that would be useful.![]()
Thanks!
I have exactly one location available for a subwoofer and a standard sized one would block part of a sliding door that’s next to it. A vertical slim form factor sub would fit there perfectly but I can’t drill anything into the walls. How much would adding the “speaker feet” add to the price?
Thank you, I appreciate it. Will send you a DM.There's this guy who does things like this custom (https://www.facebook.com/BasTiCNC) - that's one option but pretty expensive (270 euro according to him). We could get this done much cheaper if we create a larger batch, but for only a one-off the price does get pretty high.
Here's another guy selling something: https://www.nsmt-loudspeakers.com/content/speaker-outriggers
But I'll tell you what, if you order a subwoofer, we'll machine something similar to the last link, and custom make a version with holes one the side without adding anything to the price. This will be made to order, and we're already struggling a bit on delivery capacity on the cabinets at the moment, so please DM me for delivery time on something like this. We're probably talking closer to xmas.
I'm surprised more sub makers don't go for the furniture look. How do they behave with things on top of them?Added a photo to our instagram showing an example of how these subwoofers can be integrated in your living space.
