Side or Rear Speaker Recommendation - MartinLogan
joogle
Hi - please see the attached picture of my room. I am buying 2 x MartinLogan F100 speakers, 1 x C100, and now I am thinking of running wires to the walls on the side for side speakers. I was thinking of rear but because the large window is not centered, it's difficult to place rear ones. Even the side ones I am thinking if I attach on the wall or run wire through the floor to place speaker on stand.
I need speaker recommendation for that area, either MP10 (positive is low profile to stick on the wall), or go with B10 or B100 (these I may need to run the wire through the floor to place on stands).
Thanks!
I don't see a picture.
Welcome to ASR however.
Where is bed layer vs ceilint speakers?
Keep posting pictures, I love to see the step by step progress!
Picture 1 is the front where the TV will be and then Picture 3 is the rear of the room.
I need input whether to put wall speakers on the side, if so which type. Or run a wire through the floor to basically have stand speakers.
As to using in-wall vs a stand mount more about what space you have to accomodate.....personally I like the versatility of speakers not permanently mounted in one position in a wall....
