Show Us Your In-Room Speaker Response
MakeMineVinyl
Santa Fe, NM
Never Mind - this topic has already been covered in another thread. :confused:
I did a search for a thread like the one I posted but nothing came back. I guess I didn't ask the search engine nice enough. :oops:
Had some spare time an was curious what my Bose Wave music system III FR looks like to be precise what does it do when measuring the 2 EQ setting Normal (the loudness setting) an Reduce (think neutral or less bass setting). As a disclaimer I'm not by far a audio (measuring) specialist. Thats why i did a measurement with Mathaudio Room EQ (room EQ for dummies;)) software that i know by hart with good results. Probaly REW was a better choice but what the heck.:cool:
So the Bose Wave music system III is not what we know as High End stuff (forget stereo image, staging depth etc. etc.) but to get some decent likable sound in my horrible acoustic living room (suffering from WAF) it does it job more than excellent to my surprise specific the Normal setting. The Bose is used daily, Favorable station KCSM radio.
Measuring is done in 1 square meter 9 point measurement distance around 3 meters where i normally sit.
The Normal setting (compared to the Reduce setting) shows at 50hz an increase around 3db around 80hz a 2db increase is more or less noted. From 200 - 14khz an increase in the Reduce setting (compared to the Normal setting) is seen or did Bose EQ'd/lowered this range in the Normal setting who knows.
The full corrected neutral sound (white horizontal target curve) resulted in more detail bit less bass. When using other (personal subjective) target curves you could get to a more or less the desired sound. For me the Normal setting makes the sound quite good (subjectively I'm a bass head:facepalm:). It is not really practical to hookup a laptop to the Bose on a daily basis.
Reduce (Flat) setting:
Normal (Loudness) setting:
my room and the response with Arc4 room correction and my 805s on stands :)
made new measurements tonight after implementing a new signal path. First measurement and correction is with the speakers in their dayly place (not on stands)
But quite nice response 60Hz to 20kHz within approx. 4 dB.
A dip around 52 Hz (room mode - not much to do about it) and after that down to 35 Hz at -6dB. I´m quite content :-)
