In that case, you should know about the Stratosphere on eBay:
https://www.ebay.com/str/thestratosphere/Bodies/_i.html?store_cat=3&_trksid=p4429486.m3561.l161211
They buy blem guitars from major makers and part out the non-blemished parts. I have purchased several, and they have been perfect. I linked to the bodies, but they have necks, pickups, loaded pickguards, and all other parts.
They also commission their own parts, which are well made and very inexpensive.
You can save some money on the neck by finishing it yourself if you like hand-rubbed oil finishes. The method is apartment friendly. You just lightly fine sand the neck with 320 then 400 grit then sparingly rub the finish on with a piece of paper towel, wait 2 minutes, buff it back off with a clean paper towel. Do this again every 24 hours until you have 3 to 5 coats applied. Wait a few days for it to cure, then buff with a piece of old denim and again with an old T shirt. Done. A lot of people like TruOil for this. I use Minwax Antique Oil, which seems to be a less expensive version of the same thing according MSDS sheets. You can tint it with stain if you want some color.
This neck was finished that way with 5 drops of Early American stain mixed into 1 TBS of Antique Oil:
You can finish rosewood fretboards with it too. It seals and conditions the wood and makes it maintenance-free for something like 20 years. Looks really nice too. Oiling the freboard becomes a thing of the past.
