- Joined
- Feb 23, 2016
- Messages
- 20,761
- Likes
- 37,614
Would you mind schooling a 'young' buck about your thoughts here, expanding a littler more than the technical reason or your philosophy on this?
Power is what gets work done. Frank used the example earlier in the thread. One engine is 50 ft-lbs of torque at 4000 rpm, and another is 100 ft-lbs at 2000 rpm. Both make the same power. With appropriate gearing both will do the same job.
Excess power is how you accelerate and power determines top speed in a given car. A torqy, lower powered engine won't equal the results.
Now various combinations of gearing, weight and engine size might make it seem otherwise, but in the end power does work, and work done at a faster rate (higher power) is what you are after in performance. Power is the central metric to rate of work done.
