A few cars with piston engines (in the last 25 years or so) that I thought sounded pretty good:
Some things just make you happy to be alive - here are six of them...
(Photos and text taken from [and edited by me])
Saturday 21st January 23
TVR Cerbera, 1996, 47k, £31,000
A British entrant: Now, this list isn’t about the most reliable V8s, remember, so the fact they’re made by TVR doesn’t come into it, and by all accounts a well-serviced AJP8 isn’t as bad as you might think. This flat-plane crank V8 is raw and immediate, with a ferocious appetite for revs. Once you get it past 4,000rpm you’re in heaven, because that’s when it’s howling its heads off – not literally, hopefully, and as this early Cerbera had a bottom-end rebuild 10,000 miles ago that should be in good shape, too.
Maserati Gransport, 2006, 74k, £22,950
This engine was a no-brainer. Maserati’s Tipo F136 R V8 is an absolute gem of a thing, whatever it’s in. This great-value Gransport seems like the best installation: a F136 in a light-ish body just feels right. And you get a proper symphony as you explore different reaches of the rev range. It starts with the fruity, low-end warble, then builds through various stages – all equally delightful – to a high-revving, highly tuned crescendo at the top end. It’s so lovely that you don’t need a sports exhaust fitted to enjoy it, but that’s not to say you shouldn’t add one. Something like a Tubi system will release even more wonder – go on YouTube and search Maserati 4200 Tubi, look out for a Swiss-registered car hooning off from a standing start. Talk about sublime.
Ferrari 458 Speciale, 2014, 10k, £314,995
No, it’s not the same engine as the Maser’s. Well, not entirely. For a start, it’s the Tipo F136 F, not R, and here it’s 4.5-litres. Most significantly, though, it swaps the cross-plane crank for the flat-plane variety. That changes the engine’s character completely to something rather harder-edged and higher revving. Contrary to popular belief, this engine was originally Maserati's, arriving first in the 4200 in 2001. It was then developed by Ferrari when it ran out of road to increase the capacity of its F131. Its crowning glory was in the
458 Speciale, and this one that's showing 10,000 miles is the perfect spec. The Speciale raised the rev limit to 9,000rpm, which delivered 135hp per litre – an astonishing amount for a naturally aspirated V8. At the time, I believe that was the most hp per litre of any series production car, and it still outdoes the latest 992 GT3 RS. In total, that gave it 605hp, but this is about noise not power. Be in no doubt about that, though: this motor delivers high-rpm thrills to send chills down the spine.
Lexus LC500 Coupe, 2018, 15k, £57,995
The Lexus V8 deserved a place on its own merits. In part, because it’s nice to share the love around different nations, but also because it’s a darn fine motor in its own right and sounds great. It’s naturally aspirated, all aluminium, and boasts direct injection, Dual VVT-i and 32-valves. Nothing amazing there, and when it first appeared in the LS in 2007 it was just another smooth and quiet V8 – perfectly apt for a limo. That all changed when Lexus handed it over to Yamaha, who turned out the 2UR-GSE. This had new high-flow heads with high-lift cams, titanium exhaust valves and a variable length inlet tract. It meant a 5.0-litre V8 with much more freneticism at the top end and a soundtrack to match. It sounds at its very best in competition spec, in the Toyota GR DKR Hilux – in a
Saudi Dakar that was without doubt the best-sounding engine in the race – but even in road trim it’s still something to behold. And in something like this low-mileage
LC500 you get the looks to match the noise.
Ford Mustang Mach 1, 2021, 2k, £51,995
The 5.0-litre Coyote makes all the right noises, but in the
Mach 1 it has the extra twist of its snortier induction system and brace of 4.5-inch pipes sticking out the back. It adds a bit more depth of character to what’s already a very characterful lump. And the character is quite Jekyll-and-Hyde, awash with low-down torque that you ride listening to its lazy, old-school Yankee burbling, but when you go in search of the 7,500rpm limiter that all changes. About halfway round the tachometer the noise flicks from muscle car to NASCAR and takes on rather more serious edge. By that stage, it’s what you might describe as a bit rude, but in a good way.
Mercedes-AMG C63 Edition 507, 2014, 60k, £36,950
With four countries ticked off, it’s time to end in Germany. Affalterbach to be precise, and the home of AMG. The M156 was its first in-house motor and a bit special. At 6.2-litres it’s by far the biggest capacity of anything here, and that means it has the heartiest lungs. The rolling thunder it generates could easily be mistaken for something aeronautical rather than automotive. If you hear one go by it’s truly distinctive and penetrating, with a deep, bassy bellow punctuated by crisp rasps with every gear change. And you’ll still be hearing it once it’s gone by, for quite some time. This
C63 Edition 507 comes with an extra 50hp added into the mix. That was courtesy of the revised ECU, new conrods, lightweight crankshaft and forged pistons, all picked from the SLS AMG. Think of the 507, then, as God gargling with thunder and spitting lightning.
(EJ3: This last one is my personal favorite for the sound).
