I once have tested “Multi-Terminal Electromagnetic Relay” and “Multi-Terminal Snap-Toggle Switch” for this purpose (
i.e. switching the wires between passive and active SP modes), but I found they gave some “uncleanliness and/or distortions” to the total sound. Consequently, I believe that the “physical screw-up cabling connections” like in these SP cabling boards should be the best way to go with.
I carefully and completely eliminated, therefore, any magnetic susceptible (magnetizable) metal, such as screws, Y-lugs, metal plate on terminal straps, etc. in SP high-level signal wiring; please refer to my post
#4,
#250 and posts
#013(remote thread),
#023(remote thread) and
here #9(remote thread).
You would please be reminded
"the typical issue case" in this regard (even with no relation at all to my project thread) happened with first version of BUCKEYE 3 Channel Purifi Amplifier in which measurable (and I think audible) distortion was caused by iron (steel) plates at the SP binding posts, then BUCKEYE quickly and nicely replaced the parts with brass plates by a kind of recall announcement; please refer to
the specific thread on that amplifier,
amirm’s first review pointing the issue, as well as
his second preferrable review on the fixed/revised amplifier.
Furthermore, in
my post #9 on
a remote thread "Ferromagnetic materials in audio connectors", I also wrote as follows;
If you take a look inside some rather high-end HiFi amplifiers, you'll see that the SP output wiring (and power wiring?) uses non-magnetic terminals and screws made of brass (no iron at all) or pure copper. However, this is also a common-sense measure to prevent sound quality deterioration in HiFi amplifiers. I remember it being pointed out and explained in interviews with a Yamaha amplifier designer and a Rotel engineer. It is frustrating when working with magnetized screwdrivers (screwdrivers) because you can't catch the screws, though. Yamaha's and Rotel's amplifier designers had a hard time persuading the assembly workers at the amplifier factories, but in the end, they convinced them to use non-magnetic terminals and screws, giving priority to sound quality; I've also heard that the screwdriver, which uses a chuck to fix screws and bolts to the tip, was devised so that it could be used in factories. In my DIY audio setup, I have the same thing; I strictly/completely eliminate/avoid any magnetizable metal/screw in my SP cabling/connecting.
