Sheesh. I don't even know where to start. The definition of "obsolete" is challenging me, too. None of the below is rendered useless by later technology, and I use this stuff routinely.
Calculation:
-Keuffel & Esser Deci-Trig Log-Log slide rule, ca. 1945, gifted to me by my father when I was in high school, maybe two years before everything switched to digital calculators.
-Smoley's Combined Tables, because the drafting room boss I worked for at the time didn't trust digital calculators.
-TI-59 calculator, which was the most awesome and powerful tool I could imagine, until I had a chance to play with RPN
-HP11C, which I've used ever since (42 years and counting). (I have two, plus I also have an HP11C app on my iphone.)
Physical measurement:
-Lufkin micrometers probably 70 years old, I have the "+4" set--4-5", 5-6", 6-7", 7-8", 8-9", and 9-10"
-Etalon 12" vernier caliper (accurate to 0.001")
-Mauser 6" vernier caliper
-several Starrett micrometers in the 0-4" range, none of which is newer than 40 years old, though they are still made the same way today (bring your checkbook). These read to 0.0001".
-Starrett/Weber shop-grade gauge blocks with validation stickers from the 80's
-Ralmike's 0.25"-0.5" gauge pins (a pin at every thousandth in that range--these are a "minus" set, 0.0002" undersize)
-Starrett 0.060"-0.250" gauge pins that are even older than the Ralmike's set
(Machining is beyond the scope of the thread, so I won't mention the 79-year-old toolroom lathe or the 40-year-old milling machine. And toolboxes--a Gerstner from 1958 and several Kennedy and Parks boxes no newer than the 70's, etc., etc.)
Test equipment--I think I need to set a limit here, perhaps anything made before 1990. Only a couple of these were made after 1980. I do have newer test equipment on the bench as well, but that's for another thread.
-Simpson 260 meter
-Trio SSVM
-Tektronix T932 oscilloscope
-Tektronix CFC250 counter
-Tektronix CFG250 signal generator
-Power Designs power supplies
-Transistor Devices calibrated load
-HP 339A distortion analyzer
-HP 3456 6.5-digit bench DVM
-HP 5334b counter (last calibration sticker says 1991, still accurate to 0.1 Hz when measuring 10MHz)
-Keithley 179 4.5-digit DMM
-Keithley 197 5.5-digit DMM
-Fluke 8050 DMM
-Kikusui signal generator
-HP 350D precision attenuator
-General Resistance Dial-A-Source precision voltage source
-GenRad precision decade resistor
-plus whatever I'm forgetting
Rick "pictures on request" Denney
Calculation:
-Simpson 260 meter
-Trio SSVM
-Fluke 8050 DMM
