solderdude
I think cymbals are the most common musical instrument that we'd expect to have the most ultrasonic content.
I found a dry recording of a single cymbal crash that sounded like it had a lot of high frequency content, here.
Here is the spectrum of that recording, plotted in Audacity.
At 20khz it's at -53dB, the peak at 600hz is -33dB. So we are down a mere 20dB across 19,400hz. Quite a lot of HF here.
So, this recording drops off quickly after 20khz, let's be generous and assume this is because of the mic / recording format, and the real sound would just keep going more or less linearly as it appears in this chart.
And this is the best-case scenario I can think of for hearing ultrasonics in real music. Blasting cymbals at maximum volume, just to get a faint whiff of an audible difference.
We're left with arguing for the tactile sensation of ultrasonics being important, which I guess is plausible, but I'm just going to say it's not well-established enough for people to go out and spend money on it.
Here is a high-res recording of a cymbal crash that is not limited to 20kHz in a studio.
Even at the hit (purple trace) the total SPL is close to 120dB SPL (measured up close).
20kHz is at 80dBSPL (so 40dB lower).
At 30kHz 60dBSPL so 60dB down.
At 40kHz = 30dBSPL so 90dB down.
At 60kHz you would end up with 20dBSPL (even if the crash was recorded with a recording mic reaching that, 192kHz file and the JBL (or any other speaker that can reach that)
When you ever heard music with peaks in it reaching 30dB SPL you would realize this is playing so soft that you cannot even hear anything in your average living room.
That level compared to standing very close to a cymbal hit with 115 dBSPL in the most sensitive part of our hearing.
How likely is it that @lashto would need to hear those softer than a whisper sounds (40kHz) standing next to a deafening cymbal crash.
That is something entirely different to hearing test tones at 80dBSPL (or 10kHz square-waves) and thinking overtones is what they can hear.
The experiment is very simple. Use a recording that has relevant to music ultrasonic content and sample it down to 44.1/24 and up-sample it back to the original bitrate, and then use ABX and see if you can spot the difference with gear.
If you can't tell the difference then CD is good enough for you. @lashto should do this for himself to prove 100kHz BW makes sense. I believe he already found out he can't even hear 20kHz so he cannot pass the test above anyway. That is unless he believes bone conduction or other mechanisms in his brain can 'detect' 40dB SPL HF content while listening to deafening music.
@lashto is doing the 'what if' thing and thinks just because speakers, gear, audio formats exist that reach well beyond 20kHz that this proves that >20kHz is needed for 'realism'.
