I believe that Lashto has convinced himself that:
- people can actually hear (but not through the ear-canal/ear-drum) well above 25kHz, even when the sounds are faint. He bases this on the works he quoted.
- people can actually hear well below 20Hz (also not at high SPL) and use other 'senses' than the auditory channel.
There is actually some truth in that as the body can feel LF extension which adds to the experience. Unfortunately for speakers in a room this is not really possible. For ear/headphones is possible to go down to 5Hz for instance... but one will be missing the tactile feel.
- Another of his misconceptions is that recordings are all truncated sharply below 20Hz and above 20kHz and that transducers and amps do the same. The fact that most measurements only show 20-20k reinforces his belief as well as the mentioning of 'reaching 20-20k' in the folders and leaflets.
- Then he rants about microphones not reaching those limits and for some (usually specialized) mics that is true as they are shaped in FR and not flat for a reason. There are plenty of mics that far exceed the 20-20k.
- He also seems to believe speakers cannot extend above 20k based on misinterpreted 'info'.
- On top of that it looks like he believes the 'discrepancy' between live (and I assume not sound reinforced) and reproduced sound comes from some or all of the above arguments.
- he is convinced that he 'hears' with more than just his auditory channel. He is right as one also 'hears' with the eyes and body (LF extension at high SPL) and believes that low level >20kHz somehow enters the brain through bone conduction or another 'sensor' that is not defined.
Believing is a powerful incentive to have something proven and that has to be done independently.
I guess what he really wants is to have:
- DACs measured FR (in one plot) of 44kHz, 96, 192, 384 kHz sweeps (all the way down from 1Hz)
- speaker measurements up to 50kHz (from 10Hz up)
- headphone measurements from 1Hz to 50kHz
- amplifier measurements from DC to 1MHz ... just to be sure
All of this to satisfy his FOMO and 'for the science' part for those that think 20-20k is not enough.
DACs measured this way is pretty easy to do
speaker measurements from 10Hz might be a challenge even for a Klippel in a smallish room and above 20kHz requires expensive (calibrated) mics but possible. Don't know how the Klippel handles this.
Headphone measurements below 20Hz require perfect seal and is otherwise easy to do. Above 10kHz (or 15kHz for 5128) will have accuracy issues on HATS and other fixtures so the value of that remains to be seen. Also larger diameter drivers might show comb filtering even when a large membrane vibrates piston alike (which they won't at high frequencies anyway).
FR from DC to 1MHz is possible to do ... or at least to 100kHz. Certainly interesting for tube amps and today's switching amps.
I have seen many amp measurements (by Amir and others) to extend well above 20kHz so that is already covered.
In short.... Lahto's wishlist for making measurements below 20Hz and above 20kHz seems a good idea just because they are basic measurements and some of them are actually possible but rarely seen.
This thread will be an endless argument going back and forth about 'auditory channel', measurements and belief based on some 'research' that shows (or thinks he shows) is evidence.
I'm sure ABX tests will convince him he can't hear it if you truncate below 20Hz and above 20kHz but that may be because he has not seen independent measurements of gear he uses that shows it will reach 5Hz to 100kHz as that's where it matters (I assume using speakers).
