Exactly!
But if the manufacturer specs include a wide bandwidth (say 100Khz) - then you know that the slew rate & transient response will be OK (within the audible range)
IT's still nice to have DAMPENING FACTOR AND SLEW rate, a lot can be inferred from those 2.
And different years of the same make/model amp cam have enough differences particularly in DAMPEMING FACTOR) that can make a difference in whether or not you are going to use it as a subwoofer amp for your custom made subs). I believe that SLEW RATE is also a factor in the low end and how well the DAMPANING FACTOR works in controlling the starting & stopping part of the sub-woofers movement.
Lashto, while he is concerned about the deep low end, seems even more concerned about the high end (where both the SLEW RATE AND TRANSIEN RESPONSE are IMHO more important than the DAMPENING FACTOR).
I could be wrong, I have been wrong before. If you don't believe me, just ask my wife.
The reason that I put out the information on my Dahlquist M-905's is that the claimed FR is 40 Hz- 24 KHz (no parameters) and the test revealed 26 Hz-20 KHz +-2 DB.
But why wasn't isn't the 20 KHz-24 KHz that the manufacturer clamed ever tested when the claim is there?
Whether we can hear it or not, it would be nice for it to be tested (even if it's just to hold the manufacturers toes to the fire).
When Amir tests an AMP or a DAC, the test doesn't stop at 20 KHz!
IF a speaker manufacturer makes the claim of a higher than 20 KHz response, it would be nice if the speaker will actually get to the specified frequency and with what parameters.
Perhaps some of my friends whose ears are less compromised than mine, could here it (and that might be why they may think that my speaker sound like hell (when I thing that they sound great) because I haven't attenuated the very upper part of the speaker response that I don't hear.
Or maybe they think my speakers are awesome because they hear the response that goes that high.
But without knowing if anything is actually up there or what's up there at that frequency, I can't make any relative adjustments to what someone else might be hearing at that frequency.
If they are at my home and they find the upper frequency annoying, I could possibly make adjustments that they could hear & make it better or eliminate it.
