badtimeticket
- Joined
- Jun 20, 2026
- Messages
- 41
- Likes
- 30
Check out the horizontal directivity of the blades (first) vs the Palmer Orbit 11. The Blades actually look somewhat cardioid! With a similar hole that the ASCILAB C8C have
It seems like this bit hasn’t been discussed much. Is this contributing to the Blades sound?
Here’s a bit from the whitepaper
As a result, the MF driver polarity has been inverted and the filter transfer functions have been designed to priori�se smoothness in all direc�ons and reduce any troughs and peaks previously appearing in the speaker’s off-axis response around the crossover region. ”
It seems like with passive design, you can get to semi cardioid around the crossover, but this is probably more doable in the blade because of its output capabilities, and is maybe less viable in a cheaper speaker.
