Sounds like a sensible plan.
I do agree with much of what other members have said in this thread.
I’d like to add my subjective opinion that the Diamond 9 & 10 series 2-ways have some kind of audio balance magic that you may not find elsewhere easily. Vocals, perceived transients, perceived timing coherence, imaging in both depth & laterally, and pleasant overall balance won them awards.
Their neodymium soft-dome tweeters sound so much more realistic than what they’re doing with Dentons & Lintons nowadays.
If you like what you hear now with the ‘.1s’, don’t be surprised if other speakers won’t live up to the hype even if they seemingly measure amazingly. They may initially dazzle but will you want to keep listening after an hour.
https://www.stereophile.com/content/wharfedale-diamond-101-loudspeaker for what it’s worth.
I have the larger 10.2s still in daily use and I’ll never get rid of them despite also having several other larger and better-measuring speakers.
The 10.1’s were generally regarded by reviewers as even better balanced-sounding, but with a bit less bass. My listening distance is also 5m away.
If all you are looking for is more or deeper bass, then a sub would be a cheaper way and easier to hide in the room than floorstanders.
Good luck in the search but hang onto those Diamonds. (Diamonds are Forever! Ha ha).
