Hi, newbie question here. I recently bought the Topping L30 to use with the HD660S. I connect the L30 to the Xonar DX soundcard and found that I need to set the volume control at 2 o'clock with 0db gain to get it loud enough and sometimes I have to turn it close to the max. Is this expected without a DAC? It does sounds louder than just connecting the headphone directly to the Xonar DX, but should I be expecting the volume to be significant louder with just this amp alone? Do I need to get a DAC if I have to turn the volume control close to the max or something with my setup isn't right? Thanks in advance for your inputs!
