RightYou will be surprised what GLM can do.
It's especially weird because I cut Diraclive off at 300.I'm not a Dirac user and have no direct experience with it, but there are some odd things going on above 1kHz. It's doing a nice job with the bass (it's obviously not going to fully plug the ~60-80Hz null), but it seems to be dialing in a strange midrange peak on the HT towers and broadly scooping out a good deal of treble from the Genelecs before allowing it to elevate. I also wonder what would happen if you swapped the speakers' positions.
Anyway, I'm looking forward to your comparisons once you have everything dialed in.
is there any aspect of HT that you like better soundwise?
I've only been listening to my HT's for 5 days (finally finished my theater!), but the wide soundstage presentation is fantastic! They are in a small room, just 14' wide by 12' deep (soundproofed, sealed, and treated), and I feel the HTs soundstage really helps make the room sound bigger than it is.Oh definitely the wide directivity of the AMT ribbon tweeter. That tweeter plus the larger speaker size makes for a much wider soundstage/imaging experience at my 7 foot LP. It absolutely sounds better on some content. I think there is some trade-off in image precision. If the HT is very wide, the Genelec is medium wide and a more controlled and precise presentation.
It's now 1.1 meter from front wall behind the monitors. Basically if you can't get the monitors flush with a wall you need to be at least 1.1m away. (Per Genelec). And yes, an equilateral 6 foot triangle.@Mort How far away from the wall behind it? Is the listening distance now 6 feet?
Were you able to move it back and forth (cn't tell given you have space constraints). I recall somewhere it was 5cm to 60cm from the wall. Or greater than 1.1m as you have it positioned.It's now 1.1 meter from front wall behind the monitors. Basically if you can't get the monitors flush with a wall you need to be at least 1.1m away. (Per Genelec). And yes, an equilateral 6 foot triangle.
No. Closest they could be symmetrically is about 18 inches from the wall behind them which is not recommended.Were you able to move it back and forth (cn't tell given you have space constraints). I recall somewhere it was 5cm to 60cm from the wall. Or greater than 1.1m as you have it positioned.
The only question I care about now is what's your playlist for testing?It was a lot of fun anticipating the arrival of the Genelec 8361a's and they do not disappoint. It's only been a day but here are some impressions.
They are really impressive, unlike my lousy photos which give only a vague sense of their odd size in my 11x11 multi-use room. More photos tomorrow in sunlight.
- The smooth, integrated bass really has to be heard.
- Power is ridiculous, it made me laugh out loud and how effortlessly it hit 90spl on bass heavy tracks. Have not hit a limiter. The 90db HT's on a buckeye ncx500 are no slouch but it's just no match.
- It's an engaging, forward sound, maybe? Maybe that's called detail, I don't know.
- I just plugged them in, faced them forward and they instantly 'disappeared' at my 7 feet LP. The HTs take a little more adjustment to get that effect. Neat.
I'm a big fan of the Philharmonic Audio HT Towers. I love PA speakers generally for their design, value and artisanal finishes. I've owned all their speakers at one point or another. The HT Tower is my favorite for its diminutive size, high power, and flat response. I own two pair. The second set is my home theater LCR.
I had never tried the HT towers without a subwoofer because they are designed to be paired with a sub. With some DSP/REW I was rewarded with a nice frequency curve and a strong image that smoothly got to 26hz in-room! That's nice extension from my crazy room modes. I didn't miss the sub except on a few super-bass tracks that go below the 26hz, but vey few. I am interested to see how the Genelecs sound when I adjust for a few room modes and whether I can get the same lower extension. They are both on a miniDSP Flex XLR fed by a Wiim Ultra so I can just switch back and forth nearly instantly.
It sounds like you really got a lot out of being able to listen. And it sounds pretty close, with a known trade off, in a short trial period. Tough choice.
I know it does not matter for sound, but next to the HT the Genelec looks really, really fugly. Extra fug by contrast. They might bring joy to my ears, but they offend my eyes.
Not that such consideration would stop me from going that way if the sound was more to my desire, that's for sure. But I think I would have to paint them to live with them in a main room situation. They look textured enough that a vinyl wrap is probably not an option.
Tough choice, but a good choice to have in front of you!
