Should I buy a DAC?
YurtVonnegud
Greetings everybody,
I just bought my first speakers and amp (DBR62 + Fosi V3) and I need to say, I love it.
Now I'm coming to my question, I do have M2 Air with me rn and it sounds decent (I googled some and they say Apple revised the DAC at M2's and later so it makes a difference and as a plus, it doesn't use that much power so less noise compared to a desktop is normal I guess?) but I have ALC1220 on my main system and they say it nearly average but it differs with GPU load.
I do have SMSL SU-1 on my mind but I bought the whole system for a 400 Euros and now I don't wanna give another 70 euros to a DAC.
Do you think I should buy a DAC? or Do you have another alternatives which is cheaper?
You can find the best data which I can find about ALC1220 at attachments and here is the SMSL SU-1 review by Amir SMSL SU-1 Stereo DAC Review
Thank you.
No, but I do think you should buy a UMIK-1/Micbooster EM258 and SoundSource.
Room correction will give you a much bigger improvement than external DACs ever could.
The SU-1 is about as cheap as well performing external DACs get.
Thank you very much for your knowledge. As I know SoundSource is not on Windows but I can look for a good EQ alternative. What Micbooster does? I don't have any way to buy UMIK-1 in my country, I got alternatives, do you know which one would be better?
Behringer ECM8000
AUDIX TM1 PLUS
AUDIX TM1
and Do you know a guide link?
Thank you again.
Ah you're on Windows, that makes things easier.
Equalizer APO is all you need on there.
It's a measurement microphone and cheaper alternative to the UMIK-1. For details, see here:
Try searching for Moving Microphone Method on YouTube.
Thank you so much, again. Then I'll tryna buy Micbooster or Behringer and do that with EQ Apo.
