- Joined
- Jul 12, 2024
- Messages
- 3,613
- Likes
- 5,719
- Thread Starter
- #21
Even that's complex with GLM. In the US, it's an add on, but in EU it's part of a monitor package.If DSP is part of the product
Audio products should be reviewed out of the box. Improvements to the product separately.
If DSP is part of the product, then absolutely it should be reviewed. How do we know how sophisticated it is otherwise?
Applying the best case DSP to all speakers reviewed would make sense if they are about to be reviewed like Amir does with headphones.As mentioned, some loudspeakers come with built-in DSP which cannot be deactivated. Some (admittingly more affordable) speakers even come with continuous DSP-based room correction (Sonos comes to mind), or require room correction to function properly, or use DSP for continuous dynamic manipulation (such as SPL-dependent bass boost, limiter, loudness and alike).
The line between built-in DSP and separate DSP controllers or modules, is also pretty unsharp. Why review one speaker with DSP and the other one without, although a similar amount of processing power and capabilities are offered?
I agree, but that puts a huge fraction of loudspeakers reviews under question, does it not? If a loudspeaker with built-in DSP would be granted the chance to employ room correction and evade all potential room-induced problem in the reviewer´s listening room, would that not be a great advantage over speakers which are not capable of applying such correction?
Or other way ´round: Wouldn't it be a good idea to review *any* speaker, including passive ones, with maximum of external DSP applied to potentially maxed out sound quality, to have a common ground for reviewing? I would consider that fair, and for the average reader it would mean a more realistic judgment about the maximum of sound quality achievable under given circumstances.
There is an implication to this except from being time-consuming and demanding extensive experience from the reviewer, though: anechoic frequency response measurements and subjective judgment of direct sound tonality as parts of the review would be rendered almost obsolete (if we exclude ridiculous flaws which cannot be properly equalized, such as resonance-induced issues or cancellation). Almost any curve can anyways achieved with the help of DSP, and availability of DSP is as cheap as it is easy nowadays.
But there is no hack here... A car has loads of options that you can enable or disable. Do you think cars get reviewed without them? Should a 4x4 Jeep be tested in rough terrain without engaging the Four Wheel Drive? That doesn't make any sense...NO. Audio products should be reviewed out of the box. Improvements to the product separately. Cars shouldn't be tested with ECM hacks etc.
the applied DSP should be tested prior to it, possibly comparing it with others so to know the best case one.
Seems enormous to me.
the value of such built-in features does give it a major advantage vs a passive speaker,
How would one go about doing this kind of testing halfway objectively? I don't exactly know.
A better analogy is probably traction control, ie a function that tames the raw mechanical output in a way that makes it more pleasant. A car designed with TC in mind will be a very different experience when TC is disabled - and the same can be true of DSP.NO. Audio products should be reviewed out of the box. Improvements to the product separately. Cars shouldn't be tested with ECM hacks etc.
Maybe, and Amir often already does this by EQ'ing the speaker based on his measurements, and reports how it sounds with those corrections applied. But then the correction is not part of the product, and you'll have to buy it separately.And what about a passive speaker plus an amplifier or streamer having DSP capability? I mean, such are easily available nowadays, or even part of certain software like roon. If we count that in with active DSP speakers, maybe we should grant passive models the same opportunity.
I think a speaker should rarely have an absolute verdict. I see no point, given that you have so much data; condensing it to a single verdict is not very useful. Adding more data will not change this.Maybe it would be a good idea to just admit that such level of objectivity in testing is simply not possible? In my understanding, that has an implication for any type of absolute verdict in a speaker review, particularly if referring to aspects which can easily be changed using DSP (such as the anechoic response).
(I'm not aware of any speaker that cannot be operated without prior measurement to fit any processing to the true circumstances)
the basic speaker test IMHO should be done without this feature but good practice would suggest that the feature is tested in a follow-up or two-part review, using the same setup at at the same time of course, for fair comparison of the feature on/off without any other variables changed.
And if you only review it subjectively, it doesn't matter anyway, because it's subjective, anything goes.
Even with traditional designs you can still use external EQ, reducing room gain ( boomy bass) will hugely improve the sound you hear.
From what I can find on the web nothing stops you to install and use these Sonos speakers with Trueplay turned off (there is switch in the mobile app).Sonos Era series with its built-in Trueplay algorithm is an example.
As DSP can be done in a good and a bad way - result not related to the DUT - it should be done only as part of the subjective listening test.Erin (Audio Corner) got a lot of flak when he reviewed the Genelec 8361a without GLM, the Genelec bass management, active crossover, and DSP system.
The Genelec army pointed out that GLM is made by the manufacturer and designed only to be used by Genelec SAM products. It should be tested as actually used.
Erin understood those points and responded with good points like doesn't that put passives at a disadvantage? And it takes up a lot more time to test DSP.
There's a lot more to say about it, obviously. I think Erin promised to include GLM if they send him an 8380 to review. I hope they do.
tl:dr When should DSP be a part of an audio measurement review?
Who on earth would use an AVR without DSP on?There is a better analogy: should an AVR be tested with DSP? Still the answer is not obvious. I would like to see tests with DSP.
