Pareto Pragmatic
As others have said, not really much of a concern. However, there are ways it can be a concern.
One that I never thought about before reading about it here is that if one is using a DAC as a preamp, some failure might send full power to the speakers. I don't know if that is likely from a circuit glitch or a software glitch that switches modes without warning or input. Or from user error.
If one has the knowledge, it is possible to get a volume control that fails in a way that breaks the circuit, not that lets full power through. Think fail safe, not fail proof.
You can also put fuses in place to protect drivers, which is going to cover things like people turning up the volume way too high.
Me? My main speakers will take the full power of my amp without breaking. I did not buy them for that reason, but I certainly like that is how it worked out. Because I am using my DAC as a preamp.
Keep hoping! I've found that there is depth to pretty much every topic that seems simple. In all fields.
Given triamping, I think you are safest looking at max voltage for each driver, and using that to guide you.
If such a precaution is prudent, what is recommended when working with power amps that do not have a gain knob?
I was hoping for clear guardrails so that I’d be able to know I wasn’t risking my drivers if I stayed below such-and-such a level. While the tests described in the document sound onerous, they don’t provide a clear safe/not safe boundary. I guess the situation is too complex to allow for the simple specification I’d been seeking.
Now I’m not clear on how useful the max power spec is for any driver.
