Short power cable recommendations
terfenol-D
All, does anyone have some basic power cable recommendations? I’m trying to clean up the wiring and hiding 4 six foot cables when I only need a foot about a foot in a half in length doesn’t work well. I don’t need anything fancy just something that works.
I've never had a power cord that didn't work. :P
JSmith
JSmith
You've never been on tour with a band, then?! :) jk... In answer to the OP - I cut my cables to length and put new plugs on. If that's not feasible, short cables can be bought from suitable outlets, depending on where you are situated, so no recommendations from me...
JSmith
Thank you. This is perfect. I tend to use blue jeans cables for all my other cables and was surprised they didn’t do power cords.
I'm not sure you can get mains plugs you can wire yourself in the US, or Europe, or whether they are always molded on. Unlike our UK plugs:
However, you can get IEC C13 plugs that you can wire yourself:
You could use your existing cables, shorten them and re-attach an IEC plug.
If the power cables in question belong to an amplifier, you need to pay attention to the wire gauge. It may be using heavier-duty 16 or 14 ga. If that’s the case, using a too-small cable will starve the amplifier of current and thus reduce is power (read wattage) output.
Regards,
Wayne A. Pflughaupt
All standard C13/C14 IEC power cords are supposed to be rated for 10A 250V and typically use 18AWG wire, which is fine for normal gear like amps, PC's etc. There's no need to use 14 or 16AWG cable really... 18AWG is sufficient unless dealing with very high current and/or long cable runs.
JSmith
You can buy from Amazon and specify the length. Or you can buy cable and wire up the plug/connector of choice, yourself.
What country are you in, and what are the PC for? Power amps 14-10 gauge. Power amps that are 1-2 ohms capable, I used a pretty hefty cable. 4-16 ohm power amps 14-12 gauge. Anything other than a power amp. 18-14 gauge.
I used to build my own but those days are over, considering the price of good copper and all the pretty jewelry they can add for a few bucks. I did use a mom and pop in China until the $hit hit the fan on tariffs. I was paying 15-25.00 usd for 1-3 footers with all copper, including the terminal ends. Copper/silver clad 25-35.00 usd.
https://www.ebay.com/str/enjoyhifi/US-Power-Cable/_i.html?store_cat=17840078017. This is one that I used for over 5 years and never had a problem, even with custom request.
You can find less expensive molded cables if you like, but @enjoyhifi is pretty friggin' good considering. I've purchased 100+ cables from them alone. 1/3 were PC.
They have all kinds of cables and construction designs. I like less shielding if I can get away with it, but they certainly carry it if you need/want it.
They have a copper/silver-clad weave with copper/silver terminal ends, I like. PTFE. Tough as nails, Smooth as silk as far as chaffing and molding mauling (:-)) and very reasonable.
Have fun
Regards
You definitely can in the U.S., I've wired up a number myself. You can get the plugs at any home improvement store or electrical supply.
Monoprice has a large selection of power cords including a wide variety of terminations, wire sizes and importantly for you, cable lengths, all in one site.
JSmith
Nevertheless, IMO it's not a good idea to downgrade from what the manufacturer supplied with the product.
Regards,
Wayne A. Pflughaupt
JSmith
Generally yes for low/medium power amps.
For high power or high power multichannel ones AWG goes down rapidly sometimes but it would also be obvious cause the other end would be typically C19 type (or more for stuff like really higher power ones doubling even down to 1 Ohm.
