Ha! You're obviously gonna get some skeptisism on a forum like this with a response like that as you can see below your reply - that's to be expected.
Worse still for me in the context of scientific believability - I am hearing differences on solid state DACs by changing what lies beneath. I have no doubts about it which is why I have invested in better dedicated support furniture, where in reality I would rather spend elsewhere. I would rather have not heard any difference - then I could keep my money! In a way I'm glad I now realise this, than be ignorant to the contribution of supports, otherwise I would keep chopping and changing separates without hearing their full potential when auditioning them.
Well as a noise and vibration specialist and hifi enthusiast for 50 years I have had the opportunity to try the very best isolation contemporarily available on several bits of kit, though not recently since the lessons I learned over the years were confirmed time and time again and I see no need to repeat them any more.
It is a long story so I'll summarise.
When I was working on turntables I discovered that without extremely good isolation there is a lot of spurious pickup (Like a solid plinth TT using isolating grommets and sitting on a big solid "rigid" oak bench picked up buses driving by 4 floors down and the other side of the car park.
Almost no record players are sufficiently well isolated to -not- pick up and broadcast extraneous sound, and even if well isolated may still pick up airborne vibration. OTOH I quite like the effect, it is a bit of added reverb. When I bought the first house big enough to have the TT and electronics in one room and speakers and me in another the sound was not as enjoyable, a bit flat, to my disappointment and surprise.
I have tried expensive supports, in fact still use them since I own them and they look nice, they made no difference (I don't use any valve equipment).
For years I have used Goldmund equipment, and they are obsessed with mechanical grounding and all their higher end stuff has it.
I have tried the electronics grounded as advised and mounted on a rack and hear no difference, though, I must say, having kit designed to mount one on top of the other with grounding posts going top to bottom makes it easy and attractive and compact, but very expensive to make. I had a stack with monoblock, monoblock, DAC, Preamp, CD transport and it only took up the floor area of one amp rather than a whole wall!
My speakers are "mechanically grounded" but since they weigh 130kg each and the stand has this integrated I have never tried without. I would rather expect it to make a difference though.
I am pretty sure if you tried a level matched blind comparison the differences you hear would disappear. Try getting a friend to lift a component off the best support you own whilst you listen. Don't look to see what they are doing and don't touch the volume control.
Easy to do and a big money saver
