Shiit mody multibit 1 usb vs ddc SMSL po100 pro s/pdif
Just want to share my experience with SMSL po100 (pro). Long story short - I decided to connect my mody multibit 1 to pc not via mody usb but through a budget ddc and usb-spdif concertor SMSL po100. There will be no measurements except my ears. Spoiler - SMSL flawless victory. I’ve listened 2-3 tracks more than 10 times each. Tracks that I know. So audible difference were on high frequencies. Despite that mody already has a good detail resolution via usb-pc it sounds way too harsh, kind of more noisy-metallic on 12-18k or smth. Because of that I avoided to listen carefully to that frequency range - it were too spiky. But SMSL 100 changed that it made these frequencies smoother aka more pleasant and organized . And this has given me more RESOLUTION. Not more details but desire to listen to every detail that was already there but was too harsh and dry. That’s it) no stage, warmness etc change. Just imagine your high frequencies as wild, weed-covered overgrowth with mody usb and a well-kept lawn, mowed four days ago, with soft grass through SMSL. Where you prefer to walk? Not “can”. Prefer
Let me try to shed some light on this.
If I’m not mistaken, you still have the old Modi Multibit 1 DAC with the V1.x board.
As far as I know, that unit still uses the old CM6631A, with USB technology dating back to 2010/2011. The AD5547 DAC chip is a very dated 16-bit DAC from 2004 with rather modest measured performance.
Its only real highlight is the AK4113 receiver (the predecessor to the AK4114/8), which set the standard back in the day.
A few years ago, we conducted blind tests and measurements involving over 20 different USB DDCs, ranging from simple USB-to-I2S boards costing under €/$20 to DDCs priced above €/$2,000.
The CM6631 and CM6631A boards, in particular, stood out negatively; there was an audible difference—specifically regarding transparency—when compared to XMOS XU208 boards. Furthermore, these two boards were extremely sensitive to the PC's USB power supply.
Considering how much more advanced and superior the XU316 implementation in the PO100 Pro is, I can easily imagine a difference in transparency. This is especially true when the USB power supply is noisy, as the PO100 Pro simply performs better and is far less sensitive to such issues.
If you compare this DAC to, say, the Geek Pulse from LH Labs—which was released around the same time (or even earlier) and helped usher in the new era of (USB) DACs with its modern XMOS XU208 USB interface, ESS DAC chip, and measurements that are still considered good today—the technical gap is massive.
The technology inside the Modi Multibit 1 is now 15 years old (USB) and 22 years old (DAC). I therefore certainly wouldn't categorically rule out an audible difference in terms of transparency, even if it might not be significant.
Why not just grab a friend and do a blind comparison between the two USB inputs? Have your friend make a note of everything and see if you can consistently hear and distinguish differences. Tell your friend to mix things up—including playing the same device twice in a row.
Finally, to go with the PO100 Pro, I would recommend the SMSL SU-2; it is one of the most affordable full-fledged balanced USB DACs and boasts excellent measured performance. If needed, you also get true galvanic isolation from the computer via the optical S/PDIF connection.
And here about 80% of the audience claimed to hear a difference between regular cables and snake oil cables with crystals in their insulation layer. Do you believe in fairy tales?
Incorrect testing - > Bullish*t results. Same story every day. Please read a little on how and why your testing was flawed and your impressions are not reflecting actual changes in sound. Otherwise this discussion will run in circles and nobody will be any wiser.
Thank you yeah it’s old, but my entry into r2r. And yes, it is sound better then modern 100$ china dac. I tried to order eitr2 ddC but they don’t deliver to my country( I couldn’t find SMSL Suk-2 now it’s only ver 3 and it cost X2 of my current dac so it’s a bit strange to spend money on it. Btw do yo know how my mody recklock spdif signal? I mean how far I can go with external clocking. *Just for curiosity im not sure this dac deserve such upgrading as modern femtoreclocker. BUT at least Im pretty sure I’ll be able to hear the difference with modern r2r
About blind test. I don’t think it’s correct way to compare music. It’s like telling the difference between two spot-the-difference puzzle by looking at it one after one. Like I need not only perfect ears but also some kind of audio memory. So I mostly rely on pleasantness and listening fatigue
You are correct about the limitations of our echoic memory. However, you conclusion of then relying on even longer tests seems contradictory to me. Blind (ABX) testing and quick switching are the best methods to reliably establish audible differences.
I was referring to the SMSL SU-2. it’s a current model, and the model number has nothing to do with versioning. It costs around €100—or even less when on sale.
I won't touch Schiit DACs anymore. In our tests so far, none of them triggered that "must-have" reflex, and they didn't convince me in terms of sound quality either.
I also didn't find the latest Schiit DAC tests on ASR very impressive.
I have absolutely no time for reclockers—especially based on my own experience.
The same goes for anything labeled "femtoclock." It’s a scam to fool customers using cheap quartz crystals. That sort of thing might have been useful back around the year 2000, but far superior crystals and circuits have been available for a long time now.
The clock and jitter-reduction circuits developed in-house by SMSL and Topping are among the best on the market; they make that "femto" nonsense look like cheap junk. Just take a look at the reviews.
We have over 26 years of experience conducting very rigorous, level-matched blind tests. For us, comparing music clips lasting between 10 and a maximum of 20 seconds is ideal.
In my experience, anything else is pointless.
Why its contradictory? When you have blind test we need very good ears + *echoic memory to spot AND remember very short and tiny\minor details, textures. But long period of listening bad exhausting audio(equipment) has an accumulative effect. Believe me it is very hard to continue to listen bad\sharp\oversterile etc sound more than 3 - 4 hours
Because you acknowledge that our memory for details of sound is very limited in length and then go on to claim that listening for longer somehow compensates for the details our memory has already forgotten about by that point. That does look like a contradiction to me.
And yes, I am aware that actual listening tests like ABX require continued concentration and are essentially work and not pleasant. However, the idea that you could somehow avoid the hard and boring part of testing correctly and still get viable results by "waiting" for fatigue or counting on "accumulative effects" which may not exist is a convenient but flawed proposition. The article discussed in the post I linked above very clearly shows that it doesn't work and that quick switching is indeed required. There's no real alternative to putting in the boring leg work when it comes to generating valid listening test results.
Obvious differences that are suddenly very hard to listen to when you cannot watch... Yeah, this story practically writes itself :facepalm:
