That is what makes them even more suspect. Nobody here is saying that you are lying--just that:
- The only way to be truly sure is with blind testing
- Unless you have actually performed a blind test, you can't be sure what the results would be. I know that is frustrating, but many of us here were "converted" to this way of thinking after taking blind tests we were sure we could pass, and finding out we were wrong. (Mine was the complete and utter failure to tell any difference between 24/192, 24/96, 16/44.1, and 320 kbps MP3 after sighted testing had me convinced I that only the two highest rates sounded identical to me.)
- If it really is so obvious that you can get it 10/10 times, it probably means there is a problem with the unit or some kind of very specific equipment mismatch
- Time after time, testing has shown that even tiny differences in volume can cause the louder device to consistently be preferred, even in blind tests. It takes a voltmeter to match closely enough to be really, really sure. (Yep, I've been caught out by that, also.)
You are not going to convince anyone with subjective assessments--not to say they are not valid, just not of much real value to others. That is why this site is called Audio
Science Review. Now, if your results were actually verified in a blind test, there are plenty of users here who would be happy to help you determine the cause.
