I don't know if the Infineon amp IC they are using supports pffb. Other amps that have it are using TI silicon.i wonder why they arent slapping in pffb circuitry?
This unit is something I would like to use via USB with a pi based picoreplayer linux based streamer so this seems like it would be a deal breaker for me. If that unfixable on linux USB popping is real then it's very disappointing in what could be a promising product. For me I would have to use some sort of HAT with my Pi based streamer to avoid using USB which takes away some of the advantage of having DAC and Amp in one box.If you still have the unit, would you mind testing it for occasional and regular low-level popping when used via USB without the XMOS driver (that plagues some SMSL products and may indicate incomplete UAC2 compliance) as seen in my video?
Some notes:
- Only affects USB input (on Windows, Linux, Mac)
- After powering on, two pops are heard. Starting playback results in two more pops and a loss of the start of that track. Stopping and waiting a few seconds results in two pops, after which there will be two more pops upon playback
- The 'fix' exists for Windows only, by installing the XMOS driver, editing the XML config file to expose more Control Panel tabs, then changing the Streaming option from 'On when Needed' to 'Always On'
- No Mac or Linux XMOS driver & Control Panel, hence no such fix for those OSes
- This setting is not stored inside the unit
- Audio captured with a MOTU UltraLite mk5. The only processing performed is normalisation.
What kind of filter selection does the SW output provide? I couldn't find anything on the website but it might be a decent alternative for an AVR... at least if it had some kind of built-in PEQ functionality.
Please, consider implementing a high-pass filter for the subwoofer out for future models.
I'm not sure why SVS haven't sent one of those to Amir for testing. Maybe because they know it won't measure that well, IDK. We can only guess but this does make the Soundbase an unknown quantity in terms of quality.Thanks! Are you familiar with the SVS
Prime Wireless Pro SoundBase?
Has the MX5 been tested here? There may be a reason why they haven't sent one to Amir for testing. Aside for that the MX5 may be better in some ways. The MX5 lacks LDAC but maybe this RAW-HA1 lacks the fidelity for LDAC to be worthwhile anyway? The MX5 lacks sub out but maybe sub out is pointless without a high pass filter.Topping MX5 might be an option. It has a powerful headphone amp.
Thanks @amirm for the comprehensive review as usual. Seems like a jack of all trades and master of none - lack of PFFB and the poor headphone output sort of make it a poor product in 2024 though reasonable for the price I guess.
But considering Fosi Audio, Aiyima and WiiM now have PFFB output and even that like Fosi Audio DS2 headphone amplifier has a much more powerful headphone. Then this issue with the usb input highlighted in the thread makes me think you can assemble a similar featured setup with better measurements all around for about the same price with a few components bundled together.
I see there is a Subwoofer output? Any idea if they have a HPF on the speaker outputs if an active subwoofer is connected?
A look at the data sheet would have prevented this type of post.The UI and feature set are impressive. That said, the amp section is not significantly better at 8 ohms than the now-elderly and still dirt-cheap Aiyima A07, and it has similar load dependence. In 2024, one would think PFFB -- not to mention a respectably beefy headphone output -- would be mandatory for such products, but what do I know?....
Isn't the loxjie basically the same as this smsl? Having the same dac chip which doubles as the headphone amp should mean the same mediocre headphone amp performance too, right?It seems to be just a redesigned and slightly slimmed down AO300.
Same ICs, power supply a little simpler and cheaper, significantly longer route for the HP connection, past the power supply, display connection/control and power supply/connection.
But it is also cheaper than the AO300.
It would be interesting to see if there is a metrological difference to the AO300.
The structure of the 3rd device, Loxjie A40, seems to me to be more well thought out/cleaner, a little more complex, better constructed power supply for digital and small signal range, Bluetooth and HDMI outsourced to their own circuit board instead of squeezed in between.
From my point of view, this is also an interesting candidate for a test.
PFFB is an add-on from Ti for TPA325x ICs.
Infineon has installed feedback for the MA5332MS as standard (i.e. not as an add-on) so that the signal is deliberately fed back at the output and before the output filter.
The reasons for this are, among other things, the functionality and possibilities of the MA5332MS.
Different manufacturer, different functionality, different design decisions.
what would happen if PFFB actually had the feedback go all the way to the speaker terminals??
No, I meant at the speaker terminals of the speaker, not the amplifier.That's where PFFB is connected AFAIK -- once you're "post filter" (the "PF" in "PFFB") you're at the speaker terminals in a typical chip-based Class D circuit.
In addition, the following options are provided for advanced users:
... A two-pin connector footprint provides access to the remote sensing pins of the Purifi 1ET400A / Hypex NC500.
Please refer to the Purifi 1ET400A and Hypex NC500 data sheets for further information on how to use these two advanced features.
Also someone with extra time & patience on their hands tell me the length of speaker/return wire where the speed-of-light delay would cause problems (stability/ringing/etc) with the op-amp (or other class-D feedback control circuitry) implementing the "servo" that senses the voltage¤t remotely at the speaker terminal.Intuitively, I would imagine interference/common-mode-noise etc could be problematic in a normal passive loudspeaker setup with a potentially long sense-return wire.
But such a feature could better be used in an active speaker to compensate for the intrinsic impedance and inductance of internal wiring from amplifier to speaker terminal.
Exactly. FBH and FBC must be connected to OUTH and OUTC not more than a few cm away from the amplifier.
IMO the membership got it about right, the Wiim AMP Pro is a far better alternative.What I like:
* all in one
* very good price/performance
* no phono in
* sub out
* compact form factor
What I don't:
* performance (albeit good for the price)
I wish there were more highly-integrated products with these basic features.
| SMSL HA1 | WiiM AMP PRO | |
| POOR | 5 | 2 |
| NOT TERRIBLE | 36 | 7 |
| FINE | 55 | 36 |
| GREAT | 4 | 55 |
| PRICE | $212 | $379 |
My first post in this thread is potentially misleading: it was to showcase the glitches over USB that seem to plague many DACs -- not necessarily the RAW-HA1, which I do not own.I assume it is audible over headphone as well?
