- Joined
- Jan 15, 2020
- Messages
- 6,873
- Likes
- 16,838
It isn't though above 200 Hz see post #685.Oh I see. Thewas's measurement looks very corrected to a target lol
I believe you, it's just uncanny. I've seen you measurements in other threads and always assumed they were corrected to 1khz.It isn't though above 200 Hz see post #685.
Hi, i am not familiar with dirac live, and i see it does two things that are usually not recommended, at least to newbie humans:My LS 50 Metas + single SB 2000 crossed over at 100 Hz with PEQ and Dirac Live. Magenta is PIR with full Dirac Correction. Green is uncorrected measurement.
Now that’s how a constant directivity speaker ‘should’ measure imo @thewas.My LS 50 Metas + single SB 2000 crossed over at 100 Hz with PEQ and Dirac Live. Magenta is PIR with full Dirac Correction. Green is uncorrected measurement.
- fill dips (that one at 100 hz)
- eq the full band
Is this ok or because dirac is so smart or should we prevent it to do it?
Thanks for your insight!
No about 30". The correction is so small above 300hz, I just let it ride. Suppose I could have put a curtain there, but I didn't see the need. Also, it's crossed over at 100 hz with a Linkwitz Reilly, so given I'm working with a 600 wpc amp in the SB2000, and a 400 wpc amp (Purifi Eval1) in the Metas, I think it can handle the dip, and there's only really one big one anyway. It does sound really good, btw.There is barely any correction happening above 200Hz anyway so it shouldn’t be a big deal.
The boost at 100Hz is a little on the risky side, but since it’s handled 50\50 by the sub and the speaker it might sound okay. Usually Dirac eliminates all microphone position related dips (when it averages out all the impulse responses) so this is likely to be SBIR.
Edit: wait a minute that’s a crossover dip!
However @phoenixdogfan you should probably limit the correction to below 10Khz because I wouldn’t trust the directivity of the mic at that point, but it probably won’t make a big difference anyway. Are the speakers roughly 3.5-4 meters away from the wall behind them?
It really looks like a crossover dip though, it’s better to get it sorted out.No about 30". The correction is so small above 300hz, I just let it ride. Suppose I could have put a curtain there, but I didn't see the need. Also, it's crossed over at 100 hz with a Linkwitz Reilly, so given I'm working with a 600 wpc amp in the SB2000, and a 400 wpc amp (Purifi Eval1) in the Metas, I think it can handle the dip, and there's only really one big one anyway. It does sound really good, btw.
The metas have very little headroom at 100Hz too.That's an almost 10 dB dip though which will kill headroom. Fine if you don't crank things too loud, of course.
Did you check the acoustic alignment of the 100 Hz x-over? If the filter is a Linkwitz-Reilly the acoustic result could be completely different.No about 30". The correction is so small above 300hz, I just let it ride. Suppose I could have put a curtain there, but I didn't see the need. Also, it's crossed over at 100 hz with a Linkwitz Reilly, so given I'm working with a 600 wpc amp in the SB2000, and a 400 wpc amp (Purifi Eval1) in the Metas, I think it can handle the dip, and there's only really one big one anyway. It does sound really good, btw.
Here are 2 GRADE reports, before and after setting a minimal amount of acoustic treatment (2 Viscoutic basstraps, 2 Ekustik pannels, 1 diffusor) in my listening room.
Room is 27m², speakers are Genelec 8350A set approx 40 cm from the back wall. LP is at 2.1m from the speakers.
As said the LS50 is constant directivity only above 3 kHz. Also the original LS50 has not as high neutrality on the LW and on the directivity so that example doesn't tell much.Now that’s how a constant directivity speaker ‘should’ measure imo @thewas.
Also as I have repeatedly written that LP response depends on the room reverberation function and the listening distance.
For example the room of John Atkinson loudspeakers like the LS50 give also a flat response till some frequency, just in his room the the kink is in a higher frequency, approximately flat till 5 kHz:
Fig.7 KEF LS50 Meta, spatially averaged, 1/6-octave response in JA's listening room (red), and of original LS50 (blue).
Source: https://www.audiosciencereview.com/forum/index.php?threads/kef-ls50-bookshelf-speaker-review.11144/
That's also the reason why the correction above room transition frequency to some predefined targets usually doesn't work well, its better to EQ in that region based on anechoical measurements.
Don't worry, nothing personal, I just explain different room responses which I have seen in the now more 10 years I experiment on DRC.Thank you for the response. But please don’t take this personally in anyway (feeling some bad juju from the tone of the post), it just (understandably) stood out to me.
Don't really see why that should be more justified and the example shows also how strongly it depends on the room acoustics, Anyway, we all agree that above transition frequency equalisation should be done based on anechoic measurements so it is not really an issue. Also below unfortunately the target not only depends on the room but also on taste/recordings, due to the audio's circle of confusion unfortunately, like Toole says with a good relatively neutral basis someone can adjust bass level according to the recording.Even in JK’s measurements there is no 6dB nose dive at 1KHz but it starts rather at 6KHz which can be more reasonably justified.
So, if I wanted to address that, probably go with something like a 12db per octave high pass for the Metas?That's an almost 10 dB dip though which will kill headroom. Fine if you don't crank things too loud, of course.
After adding 2 huge towers of absorbers (2+2 pieces of 64 x 64 x 124 cm each, 32 kg/m3 density rock wool) on the corners, they really did wonders on the bass decay. Now the room is sounding very nice!I have this massive 42 Hz peak that I managed to reduce with FIR EQ, and the 14 mineral wool panels absorbed the huge reverb I had on mids and highs in my dedicated listening room (5.00 x 4.15 x 3.25 m). But still I have a massive reverb on bass that I am waiting for my supplier of panels to build them for me, tuned to 50 Hz, as I can see from the decay graph. Work in progress.
Isn't there a 5-6 dB acoustic slope between the first 100-50 Hz and then around 20 dB for the octave between 50-25 dB?So, if I wanted to address that, probably go with something like a 12db per octave high pass for the Metas?
