JoeMak
- Joined
- Sep 25, 2021
- Messages
- 1
- Likes
- 0
I have made a music player on Windows platform and want to share it with you.
SounDevil pursues high sound quality, good-looking and easy to use.
Audio engine is Surreal Engine
Design target: high fidelity playback, optional upstream and downstream correction, optional personalized timbre.
Input file format, supports DSD, WAV, FLAC, APE, AAC, DTS, MP1/2/3, AC3, AIFF, ALAC, TAK, MPC, OGG, WAVPACK, WMA.
Output interface, supports ASIO, WASAPI.
Output format, supports PCM, DSD native, DoP.
DSP uses 64bit floating-point number, adopts modern high-quality algorithm, has the functions of channel conversion, sampling rate conversion (software up-sampling), coding conversion, parameter filter, convolution filter, etc.
Also supports Direct DSD, Bit Perfect.
Network address playback, DLNA renderer.
User interface is DiVect UI
Using Direct2d as the rendering engine.
Supports any high resolution display.
Supports multiple languages.
It's free, no advertising.
https://gofile.io/d/KibnlN
https://pan.baidu.com/s/1Kmt2Bq-zwIVYzSkDnI5TBw?pwd=wgd3
