Shannon Exact64 — Quick Start
No installation is required.
No Visual Studio, runtime, or additional software is needed.
That’s it. Do not double-click the EXE — drag the WAV onto it instead.
https://drive.google.com/drive/folders/11l4urcGNRxS_3lqxpRJt7nOcFVn89gs0?usp=sharing
- Download ShannonExact64.exe.
- Drag and drop a 44.1 kHz / 16-bit stereo WAV file onto the EXE.
- Do not press Enter or click anything while SRC is running. Processing can take some time — this is normal and does not mean the application has frozen.
- When finished, the 88.2 kHz / 64-bit float WAV and _LOG.txt will appear in the same folder as the original WAV.
