Quick question.
I’ve setup my tonearm using the supplier supplied instructions (ie I balanced the tonearm and then backed off the counterweight etc to reach what should be a VTF of 1.8g).
Subsequently, I purchased a TT cartridge setup kit which included an electronic VTF scale.
Going forward, can I simply use the scale to measure VTF and then make changes to the counterbalance as necessary until I get a 1.8g (or whatever the recommended VTF is for the cart)? That is, versus first balancing the tonearm and then backing off on the counterweight? Wouldn’t the scale approach be more accurate?
Thanks in advance.
Thanks in advance.
