Servo speakers
Yep I think this works best for subs as the cone is small compared to wavelength no cone break up ! radiating area is the cones area all the time, it basically works like piston at low frequencies .
Would argue that the teqnique could be leveraged up the midbass with modern hard drivers aluminium ceramics , kevlar ,carbon ?
After the fact is a little bit misleading it's the same as negative feedback in an amplifier , eventually you reach 180 degrees phase shift and it becomes unstable , but the system must be designed for it's bandwidth .
There were quite many MFB models, also mine is trim adjusted by me so I am not sure how representative it would be, but I could do some measurements in the next weeks if there is interest.
Definitely if you have time, would love to see measurements. No pressure though ofc :)
I am not a speaker designer, and I suspect that servo feedback is not used for speakers other than subs because cone breakup modes in higher frequency drivers, among other things. The woofer acts pretty much like a piston if not driven too hard.
Like you say commonly they are used for subs and woofers although the previously mentioned 2 German high end manufacturers use them also for all other drivers but like you say you must ensure the drivers work in their application and MFB control region pistonic, i.e. before their first break up mode.
Is Yamaha's active servo technology the same as traditional MFB servo subs? Seems like its still used in their NS-SW100 & NS-SW050 subwoofer lineup. The thing that looks most important to me is the Negative Impedance Converter. Not sure if that's supposed to be an accelerometer. Anyone know?
YST system uses the same tweak as Audio Pro ace bass.
I cant remember the exact technical stuff, but a quick search gave me this.
It is true that Stig Carlsson used amplifiers with negative output resistance in a couple of his earlier designs.
ACE-Bass, amlifier-controlled euphonic ( ACE ) bass was the name of the technology used by the bass speakers that began to be sold by Audio Pro in the late 1980s.
Ace-Bass is a further development of the technology with negative output resistance where you can control the mechanical parameters of the speaker element. The technology was developed by Karl Erik Ståhl who originally called it special driving in his thesis. I have not come across any manufacturer that uses this technology except for Audio Pro and Yamaha who had a variant of it.
Someone with better memory might give a better answer.
Ace Bass was a thing in the 1980:s
Ex Audio Pro Ace Bass A4-14
2x5" inside the cabinet
How effective was it compared to other "servo corrected" subs/woofers?
I actually recognized the conversation, even though translated. It might be worth scrolling down, since a later post goes a bit deeper. It's part of a conversation, but it's pretty easy to follow even if it lacks some context like this.
Here I want to protest. There are many errors in your post that testify that you do not understand what you write. Firstly, Stig Carlsson has never used negative or negative resistance on the output. There is no such thing as ‘negative’ resistors or negative resistance values on resistors.
However, it is possible to make a clever electronic connection that works as if it were a negative impedance or negative output resistance on a final stage output. This can be achieved with positive current feedback as opposed to negative voltage feedback, which is the most common form of feedback in hifi.
Stig Carlsson had a patent on certain things regarding this and his US patent was still valid when Audio Pro sold the A4-14 in the US, which means that Stig could go to court in the US. I talked to Stig about this and he was nice to Audio Pro and Kalle Ståhl, so he did not make legal claims against Audio Pro. Stig liked Kalle Ståhl and we actually met all three of us at Stig's place a few times. I was allowed to borrow Ståhl's loudspeaker elements on several occasions, which Stig measured when I was there. Stig also did measurements on other Audio Pro products as a consulting assignment from Audio Pro.
Negative output impedance can be difficult to understand but is not really that difficult. The consequence of feedback is that the amplifier maintains its output voltage the lower the impedance of the load that loads the amplifier. If the output voltage of the amplifier is constant when loaded versus unloaded, the amplifier has zero output impedance. If the amplifier would increase the output voltage when decreasing the value of the impedance of the load, the amplifier has negative output impedance.
This is achieved with positive current feedback. In this way, the impedance of the speaker coil including the mechanical parameters can be fed back, if desired. The resistive part of the impedance, i.e. the resistance, was included in Stig Carlsson's patent. However, Kalle Ståhl also included the reactive part. Since it includes Stig's old patent which was still active in the USA, it was a patent infringement on Carlsson's old patent.
Speakers with ACE-Bass were marketed and sold by Audio Pro as early as 1978 with the A4-14 and even more from 1980 when the B2-50 bass module was launched.
The fact that Yamaha used the technology is due to the fact that Audio Pro has had various owners over the years and among them there was also a person for a time, who was called Göran Hahne (I think he was called that, if I remember correctly) who was in the hifi industry already in the 70s and also the CEO of the group of radio dealers called the A-dealers at the time it happened. I don't remember if he sold the licence to Yamaha or the whole concept or patent, Yamaha renamed the technology YST or something like that. Anyway, Stefan Pantzar bought Audio Pro after that and still owns the brand since then.
Kalle Ståhl introduced the Principle at AES (Audio Engineering Society) in 1978 if I remember correctly. The principle was later named ACE-Bass. I don't think it was called that from the beginning.
Positive current feedback is a good concept if you can utilise it sensibly and if you avoid instability and self-oscillation. What can be problematic is that the impedance curve and inductance vary depending on the position of the voice coil in the magnetic gap. This is a major non-linearity that needs to be overcome, which can be done in other ways.
One of the most knowledgeable engineers on the forums analyzes the state of the technology today:
ACE-bass is certainly a very elegant solution, but in practice it is not quite as effective as one might think:
+ Electrical control over mechanical parameters
+ Self-correcting for linear parameter variations
+ Self-correcting for non-linearities in suspension stiffness
- Increased complexity, including risk of instability via the positive feedback
- High sensitivity to nonlinearities in the BL product
- Some sensitivity to non-linearities in the inductance
- Reduced efficiency
For an active system, the reduced cavity volume cannot be seen as a real advantage - the frequency response can be managed via equalisation even without ACE bass and the maximum efficiency is given by the cavity volume.
It is therefore more efficient overall from a system perspective to use elements with high linearity and equalisation if the cavity volume is too small for a sensible frequency response.
A design of motor systems and spiders that was not elaborate by today's standards before the breakthrough of FEM, as well as a large production-related spread in the element properties, led in the seventies to quite large problems that ACE-bass handled well. However, with great advances in both element design and production, it is no coincidence that the principle is rarely used today.
So the answer to that seems to be that it's a current feedback mechanism.
To drag this post out a bit further, I was actually interested in experimenting with this a bit when picking the parts for my DIY-subwoofers. And - the first thing you need to do that is a sense of the current flow. And then I noticed this neat little thing in the Hypex nc502mp spec sheet:
Doesn't this looks exactly like what you'd need?
Worth noting that Bruno Putzeys first(?) involvement with making speakers, Grimm Audio, utilized motion feedback. Possibly through this?
Though, I had to get an old specsheet for the above screenshot, it seems like the feature was removed from the modules w revision 04xx:
Repeating a line from the above list of reason the technology isn't used that much any more:
BL product, the force factor.. and again, a bit interesting to note what the first blog post from Putzeys next project, woofers, is about:
No idea if this all actually follows a shift in Putzeys ideas about how to best reproduce audio accurately, or if it's just him making the most of the area he's focused on at the time.
This thread from 2020 just came up again and I remembered that 2 years later I had done few gated measurements:
Thanks to the MFB woofer and small 2" dome mid and even kind of waveguides not bad at all, even more considering they are from 1978!
Source of above photo: https://mfbfreaks.com/motional-feedback/hifi-apparatuur/mfb-boxen/22ah587/
Love their much ahead of time placement correction filters and frequency response plots on their front panels. :)
Ace Bass can give you a lot of bass out of a smaller tranducer.
A real servo gives you better mechanical control, not necessarily deeper bass but more accurate.
Also i have never seen +15" being used with Ace bass, Yamaha did have some 12" subs.
But i think they tweaked the system a bit, for better or worse i cant say.
Analog can work up to Mega Hertz. It isn't too slow. The cone of a woofer, seen from an average amp or opamp, is at standstill even at highest level and excursion. Compare a turtle to an F16 jet.
Phillips is a very bad example for MFB. They wanted small speaker, cheap production and high profit.
A passive speaker is a sell and forget object, an active, MFB speaker needs service. Phillips is a company with a history of very bad management, wrong decissions and lost opportunities. The management was only interested in personal profit and instant cash flow, no one cared about new or future develoments and solid growth.
A partial list of manufacturers with analog MFB:
Phillips did piezo based MFB.
Bakes&Müller did it with the cones acting as variable capacitors, even the tweeters were controlled.
T+A did an optical system with a wedge shabed moving rod, changing the light intensity of an IR diode.
Harman had resistor-voice coil based systems in some subwoofers.
B&M also used electret microphones glued to the dust cap.
In the US you get a system with a sensor coil from GR.
Today Pirate Logic has the most developed, safe and easy to implement system you can buy for DIYS. Their only fault, they still think it should be used to make small woofer deliver like large ones, instead of making large drivers better. Maybe because the Dutch love small speakers. Crazy, uhm?
Anyway, you can use their system on nearly any woofer or subwoofer.
There also was a Keenwood (?) amp with a quite useless sensor wire.
MFB does a few nice things. It reduces distortion and makes the resonance frequency less important.
How you implement it decides how it works and what result you get. IMO using it to reduce box volume and cone area is the most non HIFI approach. Some call it a very stupid idea.
If you ever heard a well done MFB woofer, you will not want to miss it. There are just too many bad examples out there.
As you can only use MDF with an active speaker, in a time when anyone wanted a buy separate amp, they did not succseed.
One critical point is that speaker drivers age and the feed back has to be adjusted accordingly if you want to get best results and a very strong effect. Also matching a driver to an MDF system is critical.
Today the market doesn't need a better woofer, it is all about marketing, influencing, not quality. As long as the old stuff sells, no one will risk money on it. For DIYS it is a very rewarding thing.
Some Mackie speakers use servo, the HR824, HR624, and HR 626 are small nearfield monitors with servo. The HRS120 studio sub uses servo. The SRM450 and SRM450V2 are PA speakers with servo, and the SWA1501 PA sub used servo.
There may be there more and I'm not sure about current products.
