tvrgeek
Several threads recently got me thinking about the basic market failure of servo speakers and the experiments I did back in the 90's. Phillips, and several subs. Looked good on the bench but sounded like crap.
At that time, the accelerometer and the second coil were the positioning sensors. Both have such high error as not to be useful unless corrected in the digital domain, which at that time could no where near approach fast enough. Feedback is by definition, after the fact. The more aggressive, the less delay, but the more power and the more unstable. To reduce the power, one method is to make an inherently unstable but fast system and tame it. The other is the slow stable system and force it faster. The latter is the method attempted. As we are dealing with significant mass, probably the only possible way.
My idea was a phase coherent optical sensor using a opto-isolator with a taper slot. I thought about a 3 phase slot sensor, but my calculations said I could not guarantee it getting out of step building an offset, though the resolution would be better. Details on mechanical precision made this impractical as well, even though it could be fast enough to use for analog negative feedback. Getting no friction and no resonance I never solved. I could not cut a sharp enough slot and the matching slit. Someone with a good photo enlarger could I suspect. On paper, it should have been able to reduce a driver below 100 Hz to the .1% range. Now I got pretty good with a pure sine wave, but a pulse was a disaster. Power required for an aggressive enough error was way more than I had. I suppose a driver could be made to withstand it. The core problem that I think wil cause this to fail is one can make one position of the cone to move correctly, voice coil for instance, but not the entire cone. No cone is perfectly rigid. So by definition, you will get distortion generated mechanically by the cone that feedback can't correct.
So if direct feedback is not possible, is it now possible with the speed of DSP processing to characterize the driver and generate algorithms that could be added ahead of time. One might need to clock a set delay and delay the mains ( integrate the crossover of course) to reduce the distortion based on a prediction. In theory, this could apply to all drivers in a system or maybe a set of cans. One only has to keep away from resonance, breakup, and excursion limits. All this can be coded. One could even code soft clipping or raising details that have fallen below the threshold of hearing. Sort of edge compression.
I guess the money is being spent on 16 channel AVRs, sample rates higher than any source, and video bandwidth exceeding the best IMax camera to display on a 40 inch screen. Ironic. Back in the '60s, AR did some research to see how many channels was necessary to give a person true 3D positioning. Yup. 16. But not for pure tones. Turns out with a pure tone, you can't localize in space outside a plane splitting you in half vertically. Add a tiny bit of noise or a second tone, and bingo! Lesson was we do process phase as well as time and frequency information.
Anyway, food for thought. Maybe someone smarter than I can make some progress. What may be possible may not be economical.
