- Joined
- Oct 25, 2019
- Messages
- 12,491
- Likes
- 18,102
Yes it matters . Next time is a warning and a thread banDoes it matter if the quote is worded differently? As a result, does everyone know what their comment was?
The comment wasn't even dimly critical. It explained exactly what to compare, in a kind tone.I would appreciate it if you could teach me how to compare instead of criticizing.
I'm more concerned about the parts written in English. This is an opamp rolling thread on ASR. There are websites devoted to the counterproductive practice of rolling opamps where anybody who questions the practice is banned. Is it on the ASR membership to debug every bogus circuit application with infinite patience and tolerance to pushback?Yes it matters . Next time is a warning and a thread ban
Never heard of any DAC having issues if it was USB 2.0 (or even earlier) playing via USB 3.0 in any situation.I plan to complete all these efforts. Just comparisons with computer testing software are enough for me.
I'm using it a little more roughly because I don't have as much detailed information as you. I ask you to comment by putting yourself in my shoes, that is, by empathizing.
Ama bunu sıfırdan yaparsanız kendinizden ne kadar memnun kalacağınızı düşünün.
We apologize for the translation error.
Yes, I tried Maxtech drivers and found them really successful. Anker Q30 headphones have high sound power at 600ohms and with the equalizer, they have outputs that are strong enough to damage the ear. In my research, I saw that the topping d30 ll was very successful, of course, but since it did not have a bluetooth feature, I preferred the fiio bta30pro. I also play my music albums with foobar or roon and use asio or wasapi. The USB interface is good, but stability problems may occur between 2.0 and 3.0. For example, it supports DAC 2.0, but there is no port other than USB 3.0 on my computer. How can we?
It works but is not stable.
Blocking every roller is counterproductive to building the ASR membership.The comment wasn't even dimly critical. It explained exactly what to compare, in a kind tone.
Master opamp rolling thread is one option.Blocking every roller is counterproductive to building the ASR membership.![]()
Sure. Then MODs can dump the rolling arguments and rubbish into that thread. I am a bit tired of the steady flow of rollers coming here with their buzz words and seemingly just here to tell what they are doing and not listen to reason.we could have an actual opamp rolling thread
While the Maxtech drivers worked better than stock (horrible) Asus drivers, I did sometimes have stability issues with ASIO and Maxtech.Yes, I tried Maxtech drivers and found them really successful. Anker Q30 headphones have high sound power at 600ohms and with the equalizer, they have outputs that are strong enough to damage the ear. In my research, I saw that the topping d30 ll was very successful, of course, but since it did not have a bluetooth feature, I preferred the fiio bta30pro. I also play my music albums with foobar or roon and use asio or wasapi. The USB interface is good, but stability problems may occur between 2.0 and 3.0. For example, it supports DAC 2.0, but there is no port other than USB 3.0 on my computer. How can we?
Yeah, good description, and we are collectively fatigued with this.Sure. Then MODs can dump the rolling arguments and rubbish into that thread. I am a bit tired of the steady flow of rollers coming here with their buzz words and seemingly just here to tell what they are doing and not listen to reason.
"Op-amp rolling" isn't even a legitimate thing, actually.
A dedicated thread for it makes about as much sense as the practice itself.
Dave Reite.
Should we make it a somewhat taboo and shady practice that audiophiles do on the downlow?"Op-amp rolling" isn't even a legitimate thing, actually.
Dave Reite.
I don't care what anyone sticks in any socket as long as it's safe . But if they want to claim on here the result is better than stock they need measurements and / or controlled tests .Should we make it a somewhat taboo and shady practice that audiophiles do on the downlow?
Create a forum for all this nonsense, move the threads into it and let people question/argue AI chatbots to keep them away from the rest of the site? (Sort of like how if you cheat at the chess site lichess.org your account gets marked and you only get paired with other cheats).Should we make it a somewhat taboo and shady practice that audiophiles do on the downlow?
It doesnt work . We still get umpteen new threads a week asking which dac does /should /would sound better .Create a forum for all this nonsense, move the threads into it and let people question/argue AI chatbots to keep them away from the rest of the site? (Sort of like how if you cheat at the chess site lichess.org your account gets marked and you only get paired with other cheats).
Then that should be your approach. Promote safety. And rebut fantastical claims .Who says op-rolling is safe? It's easily possible an alternative op-amp could cause a serious circuit oscillation and destroy some tweeters
Not sure about that (separate thread). We don't do that for cables, bi-wiring, crossover upgrades etc.Create a forum for all this nonsense, move the threads into it and let people question/argue AI chatbots to keep them away from the rest of the site? (Sort of like how if you cheat at the chess site lichess.org your account gets marked and you only get paired with other cheats).
As others have pointed out, rolling opamps is futile and can be dangerous if you don't know the circuit and how it works.Seeking Op-Amp Upgrade Advice for Asus Xonar Essence STX
Any suggestions or insights are much appreciated!
Who says op-rolling is safe? It's easily possible an alternative op-amp could cause a serious circuit oscillation and destroy some tweeters.
When you're dealing with audiophiles, you have to assume worst-case experimentation is the norm.
Dave Reite.
Blowing some tweeters is not what I consider unsafe. Unsafe for me is whether fiddling or changing can lead to physical harm. IF op amp rolling can lead to that, then of course a non-knowledgeable person should not do such a thing. Tinker with electronics and then plug the cord into the wall socket for power to the same thing with which was fiddled.Well. Hm.Then that should be your approach. Promote safety. And rebut fantastical claims .
That's right! And I plan to do that soon. I still have that sound card in my PC after 15 years, and I have a bunch of different op amps that will fit it, including the stock ones.I don't care what anyone sticks in any socket as long as it's safe . But if they want to claim on here the result is better than stock they need measurements and / or controlled tests .
Be prepared to be disappointed.That's right! And I plan to do that soon. I still have that sound card in my PC after 15 years, and I have a bunch of different op amps that will fit it, including the stock ones.
I doubt it will make any significant impact, but now I have a good ADC for audio measurements, an AES17 notch filter, and REW / MultiTone apps, and we can compare the objective output results of the op amp rolls.
