The third sample is distorted so all bets are off.Blind test the original files.
Then ...normalize all 3 files... check for same volume/LUFS etc to be within 0.1dB.
Blind test these equal volume samples.
Report here.
Report here.
Which is exactly why swapping op amps will, at best, have no benefit, but will far more likely make things worse. It's a stupid thing to do.
So is the NE5532 at 1/100 the cost and a much smaller package.I only glanced at the datasheet but the Sparkos stuff seems like a quite conventional "objectivist-friendly" design. It's always possible misusing it in the wrong circuit will cause issues but it's a fine audio op-amp.
Oscillation, perhaps?frequency response is strange (those consistent frequency lines across the recording
What would be the point of that test - it won't show the measurable/audible impact of an opamp in actual use.Am I correct in saying that the tests were carried out by replacing the OPAMP in the buffer / input stage of a class D amp?
If so, any distortions etc. will be completely masked by those of the amp surely?
I suggest that the proper way to test for differences (audible or otherwise) between OPAMPS would be to use a reference circuit with an average gain (around x3 to x5) and then insert this reference in the source path and listen / measure.
To compensate for the additional gain, a simple resistive divider could be inserted on the output of the reference circuit, to enable level matching.
The OPAMP would be in actual use though, as part of the reference circuit - if trying to demonstrate audible differences, it doesn't matter what circuit it's inserted into.What would be the point of that test - it won't show the measurable/audible impact of an opamp in actual use.
The original test does exactly that.
It's clear that different opamps measure differently. The point of this thread is to determine if that makes any practical difference for hifi ... it doesn't
What reference circuit? Some opamps need external compensation. Some opamps are better at driving capacitive loads so need a smaller external isolation resistor. Some opamps can drive larger loads etc., etc. Thats why manufacturers make dozens of different opamps. When designing you pick the opamp thats best suited to your application, the circuit its in, including the source and load. Than how do you make a reference circuit thats good for all opamps ?If it was remotely possible to hear subtle differences between OPAMPS then surely the best test method would be a reference circuit as I suggested, followed by a very good quality headphone amp and headphones.
I think so, yes.Am I correct in saying that the tests were carried out by replacing the OPAMP in the buffer / input stage of a class D amp?
Yes, of course.If so, any distortions etc. will be completely masked by those of the amp surely?
This kind of test may be useful, but that's not what this thread is about. It's about opamp rolling, replacing an opamp in a given circuit by another one.I suggest that the proper way to test for differences (audible or otherwise) between OPAMPS would be to use a reference circuit with an average gain (around x3 to x5) and then insert this reference in the source path and listen / measure.
... which doesn't make sense as the LM49720 is one of the very best opamps available. Chances are high that rolling in other types makes things worse, not better.Also, this Fosi Audio ZD3 ($180, 117 dB SINAD) equipped with the latest DAC chip (ES9039Q2M) has the ability to replace balanced (2 pcs., Left/Right) and unbalanced (1 pc., both channels) operational amplifiers.
The latter. He is a charlatan.The obvious suspicion is really sloppy test setup, making it worthless. The worse suspicion is deliberate manipulation to fabricate perceivable differences.
+1,000,000 yes yes yes...what is it that people do not understand about this.Making a test non-blind NEVER makes it more reliable.
And in the unit pictured they used high quality machined sockets, at least it appears so.Also, this Fosi Audio ZD3 ($180, 117 dB SINAD) equipped with the latest DAC chip (ES9039Q2M) has the ability to replace balanced (2 pcs., Left/Right) and unbalanced (1 pc., both channels) operational amplifiers.
It's an ego-driven, narcissistic tendency that prevents admitting to being wrong or having been misled by a clever salesperson. Acknowledging that you’ve been outsmarted and essentially lost money can be a tough pill to swallow.+1,000,000 yes yes yes...what is it that people do not understand about this.
