If you haven't had any particular reason to look into the psychoacoustics side of things, which most of us haven't, you are likely to feel like a lot of blanks get filled in when you do. The brain is a tricky beast, and plays games that good marketing and salesmen will capitalize on. We are all about subjective testing and comparisons, but only when they are controlled with enough rigor to be meaningful.
I agree with what you said. It means to consider the psychoacoustics side of things. I will search this topic and read it later. The human brain is a slave to hormones.
I approached high-end audio easily at first because the prices have gone up so absurdly these days, so I thought, what is a normal price and what do you think?
But now I am learning through this conversation. I learned about many topics that I didn't care about, and I will study about them. I will dig deeper into the "psychology" part that you guys keep talking about.
A filter on the ADC side is to reduce aliasing. Which isn't distortion exactly. Properly designed the filters at both ends let you record, transmit and reproduce the original signal that was sampled within the bandwidth you want. Filters really aren't a personal preference. Since some odd filters cause some mildly audible effects some treat them this way. Personally I think multiple filters on the DAC output is a bad idea. If you want to alter the EQ doing so with precision using EQ makes a lot more sense than messing around with various output filters.
Thanks for the detailed explanation. I understand that the filter is created to produce proper ADC results within the human audible frequency range. But what if there is a subtle difference in sound? It's not a huge difference, but that's what I meant when I said that there is a personal preference part.
If there is a correct answer, there is no need for various filters. Depending on the recorded sound source condition, the filter may need to be changed, and it is made so that the filter can be changed according to the variable. That's why I said "personal preference" in that sense.
Honestly, most people will hardly hear the sound difference due to the filter difference, so it doesn't mean much.
As you mentioned, setting the EQ properly is more important for sound reproduction. That's why I also use ROON to adjust the EQ after setting the hardware. That way, I can change the sound reproduction results in physically impossible situations.
That's why I recommend people to use ROON or a product that can modify the EQ. As I mentioned in other posts, people in my area who use stereo hi-fi speaker systems have a strong stereotype that "you should never use EQ."
I actively insist that it should be used.
Another example is that if you set the woofer properly in a 2.1 channel setup, you can fill in the lack of bass due to the speaker system and space. But the funny thing is, dealers absolutely do not allow you to install woofers. Do you know why?
"If you lack bass, you should use a larger tallboy speaker. You can't hear proper sound with a woofer." They say this. Because woofers are much cheaper. Compared to large tallboy speakers.
They unconditionally recommend a system that makes them more money. That's why I don't use woofers in my area. They look at you like a weirdo if you use a woofer.
No, if the sound is awkward, just use two woofers. You can fill in the lack of bass if you set the crossover well. Even Wilson Audio training says to actively use it depending on the situation. If you set it well, you can make up for the lack.
The easiest thing to do among the options we can choose is software EQ. ROON EQ is good.
Anyway, I'm not too old-fashioned. I'll learn what I have to learn?
