- Joined
- Apr 19, 2021
- Messages
- 427
- Likes
- 589
It’s just more of the same, overconfident audio enthusiasts clinging to anecdotal beliefs about DACs and amps, confusing personal bias with audibility.
No need to go at all! Some do-it-yourself amp kits can be spectacularly well made with careful wiring looms, good heatsinking and general internal layout, sometimes better than some cost-conscious mass-produced products. Less well compromised payouts may well introduce measured differences, but whether you'd actually 'HEAR' the difference, I don't know - human hearing is dire compared to the animal world, yet some 'golden ears' think they're fantastic at hearing differences. Perceiving multi-sensory differences, yes, but I repeat it's not just on hearing alone.Ok.
This is also my last post in this thread.
I assure you that a KIT amplifier made with modest components, just by the fact of being assembled and soldered by me, will sound worse than one assembled and soldered in an amplifier factory, even if it were the same one.
In any case, it has been a pleasure to chat politely in this thread.
OK, but if you already read about what blind tests are for, you know that the usual 'listening' can produce 'notable differences' that aren't real.I have read the Matrix tests on occasion.
I have a basic audio system and I have listened to some other higher level equipment and there are notable differences.
The ironyunfiltered goodness
while I like my apple juice unfiltered, after some experimenting I found I preferred the OS mode on this DAC.The irony![]()
Never heard of the Crystal edition, Google comes up empty as well.it'd be an interesting academic study to bench a K11 Crystal edition vs the K11 R2R
Fiio claim only 72dB Sinad. (THD+N = 0.025%) and it is all distortion since SNR is better than 115dBI have gotten the chance to listen to one of my favorite albums on the Fiio K11 R2R as a music DAC in my system. I'm on the first song and it's pretty great to hear the improvements / changes to the sound over my SMSL DO100 Pro, particularly in the areas of weight, texture, and listenability. One thing is for sure, the Fiio puts out a less hot signal. I can turn it up all the way to 99 and turn up the pre-amp to a full 9 o'clock on the volume. Using my DO100 Pro like this would be WAY too loud. So it's a better match for my system. I wish it had a remote control though.
Just a subjective impression, this dac seems to have a smaller soundstage and I'm wondering if this is related to the low SINAD. There is something less open about it compared to my other DAC, but it seems to do well with simpler arrangements (less complex sounding recordings.)Fiio claim only 72dB Sinad. (THD+N = 0.025%) and it is all distortion since SNR is better than 115dB
It's actually unlikely you can hear distortion at -72dB - most cannot on music, so it is quite likely what you are hearing are the result of perceptive biases.
However - even if you are hearing a real difference - it is only distortion. The opposite of HiFi (objectively by their own specs, mid Fi at best), and nothing magic.
Just..... indeed.Just a subjective impression,
Since the Fiio K11 R2R has no remote control it can't really work in my main system so I moved to my bookshelf speaker desktop setup. I was having some issues with the bass being too much and the sound not seeming natural, a problem I had with another Fiio DAC I tried that I ended up returning. Using a silver IC seemed to help. Also I'm using OS mode for a better sound (imo.)
I still perceive audible differences between my various DACs.
Which controls?Have you gone through the hassle of setting up some basic controls for your comparisons?
If not, you might want to give it a try.
