wgb113
Going back to a more traditional setup from active speakers to passive speakers + amplification. Budget is $10K total so I'm trying to decide whether to go with separates on the amplification side and I'm having trouble deciding.
Sources are:
The plan is to go with 3-way floorstanders and start with 2 subs and potentially go to as many as 4 if needed to tame the bass.
Something as simple as the NAD M33 is very tempting as is their C658/C298 combo but both seem to be plagued with various bugs that eventually get addressed with firmware updates but I could see that getting annoying rather quickly. It seems they're trying to cram too much into one (or two) boxes that just aren't ready for prime time.
On the power side if I went separate I'd like stick to a stereo amplifier with my budget. The only option I've considered are Schiit monoblocks or two Parasound A23+ instead of one A21+.
On the "preamp" side it seems to be a choice between "tick all of the boxes, even ones I might not need" or "source selector + gain". That NAD C658 for instance again has a lot going for it in terms of features but performance and real-world feedback leave me underwhelmed. On the opposite end of the spectrum would be something like the Schiit Freya (S preferably if I can find one used).
In terms of integrated amps there seems to be a little more of a spread regarding features when you look at what's available from the likes of NAD, Rotel, Parasound, Hegel, etc. The question there goes back to the questions from a preamp standpoint - already having a nice DAC and phono preamp could I just add bass management/DRC through a miniDSP to something more basic like a used McIntosh integrated?
Speakers are pretty much decided on: a floorstander from KEF R series (leaning towards R11) with subs being a pair of SVS PB-1000 Pros.
Sources are:
- Mac Mini running Roon
- Cambridge Audio CXC to RME ADI-2 DAC FS
- Technics SL-1200GR to PS Audio NuWave Phono Converter
