Several questions on more or less the same subject.
I have the yamaha two-way budget bookshelf NX-100, paired with the Ampapa D1 and a cheap small sub . The setup works quite well, I think thanks to high pass filter in the D1. The bass register in the NX is tight/controlled/rich and more then ok, the midrange and treble is a bit lacking, for my ears atleast. I`ve tried to compensate the weakness in midrange/treble with PEQ but the speakers just not have it in them. .I tried adding separate bullet horn tweeters (I know they are Big Satan here
) to boost the treble and it does what it was supposed to do (even though they create some expected emphasised SSS-sound here and there in the ultra the top register but it´s partly tamed a with a provisory baffle.
Isn´t it optimal, for bookshelf speakers, with woofer + midrange and a treble tweeter added in a separate micro cabinet that can be easly placed/directed? Like this AI pic:
Would it be worth, as a budget tweak, to replace the crossover with a 3-way and the 95mm tweeter in the NX with a midrange and then add a proper treble tweeter in a separate cabinet as in the picture. Is it a big chance I would end up with frustration and a lot of surplus elements lying around and maybe an experince richer (as in the normal outcome for such projects
