Sennheiser IE200 Interior
Sebby
Milan, Italy
Although the dome material appears quite simple—almost oddly so—the rest of the construction seems fairly complex. The nozzle seems to have some internal chambers, though I doubt they're necessary from an acoustic standpoint. On the front side of the driver (which is sealed), there was a layer of tape that I removed before taking the photos.
Interestingly, the driver’s output hole is misaligned with the nozzle opening. By disassembling and rotating the driver, you can get them to align, but it’s strange that they aren't matched by default.
One downside is the solder joints—they came off without even being touched. Now I understand why so many users of the IE200, IE600, and IE900 have reported drivers suddenly failing. I had similar issues with my IE600, and fortunately, Sennheiser replaced them. It seems that despite all the impressive engineering, Sennheiser tends to overlook some very basic things.
I tried using them without the tuning filter on the nozzle and, while they were a bit tiring on vocals, on acoustic and orchestral tracks I got a "wow" effect.
Removing and putting the tuning filters on is a breeze and the operation can be repeated many times.
It's okay, I had quite a bit of fun with it :)
Now do the same with an IE900, you may need a dremel ;)
They all use the same driver don’t they?,
They all come apart the same way in the end, ahahah. The dome looks identical but, apart from the Helmholtz chambers, the interior and various filters are different. They are the same family of drivers, that's for sure. In fact, the IE200 also has a chamber, in fact the entire nozzle will have been recycled from the IE300 since it is identical, but there is no plate system in front of the driver that conducts the sound to the chamber
