- Joined
- Jul 9, 2020
- Messages
- 966
- Likes
- 2,223
And let’s be honest - even without hearing any content above 12k, grandpa actually listened to good music.
Agree to a point ... I am with you with theThis is ridiculous.
I still listen to real life with the same ears I use to listen to my hifi.
I have seen this sort of comment before about compensating for age related hearing loss and there is not even a tiny glimmer of logic to it.
My reference is the outside world and the many, many more concerts I have been to since I was young and, hence, a much keener knowledge of what real acoustic music, as opposed to music from speakers, actually sounds like.
Any relationship with my age is more knowledge and experience. When I was young and had pretty well only heard music over speakers, and almost exclusively pop music at that, I am sure I would have liked the preference curve Harman have assembled from a lot of listeners.
Now I am very much more knowledgeable and experienced I definitely do not.
Talking preference back in the day nearly everybody I knew had the "loudness" contour on and/or the bass turned up. "Preference" IME has little to do with accurate reproduction.
I tried the toilet paper mod which was just putting in one ply of toilet paper, and even though it doesn't have the same frequency response effect it is still about taming the highs, and I felt that it adversely affected the soundstage vs an EQ that did broadly the same. It's hard to compare, but that was what I thought I was experiencing. I'd be tempted to just use EQ rather than physical mods.DMS has made a wee filter to sit in the HD800 enclosure to tame the 6kHz peak, may be of use to some who eschew using eq
Really good point actually that Ralph. These are un measurable quantities and basically what we are hearing is an effect. This is true for lots of transducers actually and the effect the cabinet, design and room they are used in will all have an effect. Room isn’t as much of a factor with headphones of course but perhaps it is the size and how these headphones are designed that makes them so different than other types at what they do really well. The drivers are good of course but it’s the sum of the parts which make them standout from other designs so much as well.Here's something I think makes the HD800s unique. We hear terms like spaciousness and imaging but we can't measure these because these are ambiguous terms that can mean anything to infinite degrees. Transducer design is by FAR the most important criteria. Factors such as Field strength(H), Flux density(B), permeability(u) of the magnet, Inductance(L) of the coil, not to mention the geometries of both. Seems like speaker diaphragm material has been exhausted, but the electric and magnetic fields play the most important role. That's what makes the sound!
Toilet paper really is a bit of a pointless exercise if you ask me, same as changing speaker cable to adjust the sound. Both can be done to a much greater effect with EQ'ing to preference, and that can be done digitally as well so why fuss over physical manipulation.There are instruments that measure all those parameters. Sennheiser guards them because they are important. I agree that there are lots of factors that go into speaker design...but it all comes down to a matter of degree. I've read about half the replies and was more confused afterwards. Are they listening to well mastered FLAC files, do they use proper amps and DACs? There seems to be no standards. Instead some people think stuffing toilet paper is an improvement. Are we arguing about a flea fart in a tornado or should we look at critical design criteria. There, I feel better now.
I can't argue with that. I'm not comparing it to any thing. It's just criteria that is never mentioned but is at least as important as any of the things in your list. I owe my headphone and amp buying decisions based on Amir's evaluation. He's doing the lord's work, but maybe we're approaching this wrong. Instead of only analyzing FR and SNRs, which are very important. We should concentrate also on the transducers.
If I had based my buying decision solely on the test results, I would not have purchased these HPs.
When we evaluate HPs we play detective and try to figure out what makes them sound good. This is proving difficult since we can't rely solely on test results. it just seems more logical to go to the source of the sound wave and evaluate the parameters and better yet, duplicate those physical, electrical and magnetic properties that create the unique HP800 sounds. Where would you start if you had to design something like this?Amir provides a consistent and informative test suite: frequency response relative to the Harman target, distortion, sensitivity, and listening impressions with and without EQ. That’s a solid foundation for shortlisting headphones.
That said, headphone measurements aren’t exact - unit variation exists, and no one’s head or ears match the measurement rigs. What matters is the frequency response you get on your head, whether it seals properly, feels comfortable and sounds right to you (your preference). EQ gives you flexibility to tailor the sound if the distortion is low enough. Evaluating transducers/drivers won't change that.
Yeah, that's why we need to try headphones before committing. A good example is HD800S vs. DCA Stealth. The HD800S has a less ideal frequency response, but it’s consistent across heads and takes EQ well. The Stealth measures better on paper, but its performance is highly dependent on seal and position variation.
Companies that are bought out are more interested in cutting cost and appealing to the masses.To recreate HD800 sound? - I have no idea.
I'm waiting for Sennheiser to release an HD800s successor - something new and different, rather than repackaging various 6xx models. But with Axel Grell leaving and Sennheiser shutting down it's R&D (according to him), I'm not holding my breath.
I know. I can't stop listening to all my Dire Straits and Steely Dan recordings with these HPs.Subjective as it may be I've never heard anything that comes close to the way detail is delivered to my ears and the spotlight they put on the entire recording. Heard most of the stuff out there now and speakers don't come close. However those drivers are made or whatever they do to them to get that from them. For me they are the pinnacle of what I've heard in terms of resolution, everything else is just fun to listen to now, and no need to search or spend any further as I just don't think it gets any better in terms of high fidelity transducer sonics than this, given that your ears are good enough to hear it.
Quite honestly, LOL at the expected price.HD900 rumours are about. Very exciting if true.
Rumor: Sennheiser HD900S pode ser lançado daqui uma semana - Hi-fi Hub
Seu hub que reúne de informações sobre áudio, fones, streaming de música e mais: notícias, artigos, análises, guias e recomendações.www.hifihub.com.br
