- Joined
- Jul 9, 2020
- Messages
- 965
- Likes
- 2,209
So far the most pleasant EQ settings with a bass boost are from Amir (page 1). Sound is very natural and clear with these very special spacial qualities/soundstage/instrument separation.
EQing to Harman target kills 800s in my opinion, it starts sounding very average with a poor bass quality.
However if you are not a bass head, you might find the EQ settings from Oratory for Optimum Hi-Fi target even more pleasing than any others (amazing instrument separation and soundstage). A bit strange that nobody mentioned them.
Here are the PEQ settings I use:
Preamp: -0.02 dB
Filter: ON PK Fc 225 Hz Gain -2.0 dB Q 0.35
Filter: ON PK Fc 350 Hz Gain 0.4 dB Q 2.0
Filter: ON PK Fc 1000 Hz Gain -1.3 dB Q 2.0
Filter: ON PK Fc 2800 Hz Gain -1.3 dB Q 3.0
Filter: ON PK Fc 3350 Hz Gain 1.0 dB Q 4.0
Filter: ON PK Fc 4000 Hz Gain -1.3 dB Q 6.0
Filter: ON PK Fc 5450 Hz Gain -4.4 dB Q 5.0
Filter: ON PK Fc 6150 Hz Gain -2.6 dB Q 6.0
Filter: ON HS Fc 7000 Hz Gain -5.85 dB Q 0.7
And here are the original EQ settings for Optimum Hi-Fi target from Oratory:
Preamp: -0.0 dB
Filter 1: ON PK Fc 45 Hz Gain -1.2 dB Q 0.8
Filter 2: ON PK Fc 225 Hz Gain -4.3 dB Q 0.35
Filter 3: ON PK Fc 350 Hz Gain 0.4 dB Q 2.0
Filter 4: ON PK Fc 1000 Hz Gain -1.3 dB Q 2.0
Filter 5: ON PK Fc 2800 Hz Gain -1.3 dB Q 3.0
Filter 6: ON PK Fc 3350 Hz Gain 1.0 dB Q 4.0
Filter 7: ON PK Fc 4000 Hz Gain -1.3 dB Q 6.0
Filter 8: ON PK Fc 5450 Hz Gain -4.4 dB Q 5.0
Filter 9: ON PK Fc 6150 Hz Gain -2.6 dB Q 6.0
Filter 10: ON HS Fc 7000 Hz Gain -6.0 dB Q 0.7
I do agree when EQed to Harman a chunk of soundstage and separation is gone, but I do the opposite.
Instead of going for Optimum curve with no bass, I just EQ the low end and leave everything from 1k as is - maybe just fix the 5,5k peak.
Is it correct? No, but it gives me more spacious presentation with low end, atleast to my ears.
It seems to me that HD800s' weird frequency response contributes, in no small way, to it's soundstage/spaciousness effect.
