Predatowned
- Joined
- May 7, 2020
- Messages
- 15
- Likes
- 5
Edit:
Something like this?
Yes.Something like this?
You can even get ones that don't have a cable between, just the 4.4 coming out of the back of the xlr plug. I have one, can't remember where from or how much though.View attachment 278190Figured I’d ask this question in this thread rather than start a new a new one. I have an hd800s coming and i read the new revisions come with a 4.4 balanced cable instead of the standard XLR form factor that most desktop amps use. What adapter do I need to purchase in order to use the XLR connection on my drop thx 789. Thank you!
Edit:
Or you could get a cable from Hart with interchangeable connectors. I don’t really like the stock HD800S cable, which to me is too long and bulky.View attachment 278190Figured I’d ask this question in this thread rather than start a new a new one. I have an hd800s coming and i read the new revisions come with a 4.4 balanced cable instead of the standard XLR form factor that most desktop amps use. What adapter do I need to purchase in order to use the XLR connection on my drop thx 789. Thank you!
Edit:
Oh that is a steal. At $1200 I think HD800S is unbeatable.They are $1,199 right now at Adorama. https://www.adorama.com/se506911.html?emailprice=t
Pretty tempting.
...and the deal is gone. Saved myself $1,200.Oh that is a steal. At $1200 I think HD800S is unbeatable.
Far better to use EQ rather than try to rely on some unknown interaction between headphone amps that don't measure well and perhaps have high output impedance which changes your headphone frequency response in a more unpredictable and less precise way.Try the HD 800 S using the headphone jack from an older integrated amplifier or receiver and you may be stunned at the result, and set aside your equalizer.
The Topping A90, with it's very low output impedance is a poor match for the 800 S.
I recently switched to my old NAD C352 amp from the several other's -- including Sennheiser's own Hdvd 800 -- and couldn't be happier with the results.
You are perpetuating a myth, not an objective fact.Try the HD 800 S using the headphone jack from an older integrated amplifier or receiver and you may be stunned at the result, and set aside your equalizer.
I have the HD800 and cannot confirm this, soundstage and imaging remain basically the same, independent of the EQ being used, I mean that is the charm of the HD 800(S).I've read elsewhere that EQ'ing the 800s, say with the oratory1990 preset, can adversely affect the imaging and soundstage, anyone have any experience with that or is that a non-issue?
Yes, the soundstage is absolutely affected. This effect is realised at around 7 - 9 kHz*. I simply leave the HD800 untouched in this crucial area. You can test this yourself: put in a fairly sharp peaking filter around 8 kHz, and play with the amplitude. Note how spatial effects are affected. Be careful to not make the peak too high: you could damage your hearing in this very sensitive area.I've read elsewhere that EQ'ing the 800s, say with the oratory1990 preset, can adversely affect the imaging and soundstage, anyone have any experience with that or is that a non-issue?
I am aware of the fact that Jens Blauert did write one of the most relevant books on psychoacoustics and is (or was, now retired) a leading expert in the field. But still, simply make the opposite experiment. EQ any headphone to the original frequency response of the HD 800 and I am pretty sure you will not replicate the soundstage of it. So specific frequencies certainly have an effect, but it is minor in comparison to the rest.Yes, the soundstage is absolutely affected. This effect is realised at around 7 - 9 kHz*. I simply leave the HD800 untouched in this crucial area. You can test this yourself: put in a fairly sharp peaking filter around 8 kHz, and play with the amplitude. Note how spatial effects are affected. Be careful to not make the peak too high: you could damage your hearing in this very sensitive area.
* There is work done by a German researcher, whose name I can't recall (I'll update this post when it comes to me), which demonstrates, that certain frequency ranges affect certain spatial perceptions.
Edit: Jens Blauert is the name of the researcher I was thinking of. His researcher established the existence of Blauert Bands. Play around with these areas and investigate!
In my experience, using Oratory’s EQ through Pro-Q3 running in SoundSource sounds great, with little to no change in stereo imaging or soundstage.I've read elsewhere that EQ'ing the 800s, say with the oratory1990 preset, can adversely affect the imaging and soundstage, anyone have any experience with that or is that a non-issue?
Made this by looking at crinacles 3 graphs and oratorys graph, and did some by ear. Worked really well for my specific unit.
Looks good. Here it is compared to Oratory’s with the horizontal and vertical scales adjusted.Made this by looking at crinacles 3 graphs and oratorys graph, and did some by ear. Worked really well for my specific unit.
