Sennheiser HD650 Review (Headphone)
Which of these dac/amplifiers can run the HD650 at full potential and would match the best?
  • TOPPING DX5 II Dual ESS9039Q2M 300€ 6.4W
  • FiiO K13 R2R 319€ 1.2W 2.4W
  • FiiO K7 AK4493SEQ 230€ 1.2W 2W
  • Fosi ZH3 AKM4493SEQ 200€ 0.65W 2.6W
  • Fosi Audio K7 AKM4493SEQ 200€ 0.6W 2.1W
Does the Fosi K7 do not have enough power for the HD650?
A cheap, small high-powered dongle like a JM20 Max (250mW) can definitely drive it loud enough.
Hi which EQ due you prefer ? Or use? Can you post it? Thanks
When I used the HD650 I used the Kameleon amp with HD650 module (hardware EQ solution).
Reactions: J84
Hello! I'm planning to buy an HD650 and there are three versions currently on the market, listed in chronological order of production. Which version do you think I should buy, and are there any differences in sound quality? The 2020 version (the newest) seems to be in better condition than the other two! Thank you very much!
Yes, there are differences in sound.
The grey one has a really nice box but the foam in the driver is likely to have gone gooey and does not work as designed.
Pads may also have softened up. Has a low clamping force and sounds 'warmer' than the current ones.
Most likely this is the 'black silk' variant.
When it is used the pads may have to be changed or have been already.
The newer one (silver/white silk) probably has more life on it (rear and front foam) and pads may be in a better condition.
The sound is slightly less 'warm'. Depending on the production date the sound can differ a bit.
Some might have cracked paint on the headband.
The newer ones (simple box) have higher clamping force and different pads and yet again a different sound.
If I would have to buy one again I would go for the newest version (bottom box).
Focal Clear Pro (easy FEED) > Hifiman He400SE (hard FEED) > HD560 (easy FEED) > HD650 (mid FEED)
HD600 (hard FEED)? NOT LISTENING YET
Foams discussed are all easily and cheaply replaceable aren't they?
Not the ones in the rear of the driver.
Yes.
It only has some influence on the lower mids and differs in effect that pad-wear does (the thickness/firmness of the pads).
The slight changes happen gradually over years/decades and is not sound degrading.
There are people removing the foams as it makes the sound a little warmer. I would not recommend this because the foam also prevents dust particles to enter the driver and can creep into the air-gap of the magnet.
They call this the KISS mod. They also cut away a piece of plastic holding the foam piece and start sticking dynamat all over the driver believing this 'improves sound'.
When you want to improve the sound use EQ :)
Yes.
Hahah good to know it's only changing the FR and not blowing out other aspects of the sound, sounds like a head-fi special regarding the removal of it
An SBAF special ;)
Yes.
People will tear apart a headphone just to make changes that have less of an effect than a single EQ filter.
