Hi All
I use Sennheiser HD600's as a mix reference along with the usual studio monitors. I like the overall sound and they do a decent job except in the bottom end which appears to lack any real
lows or sub. It's like there's a hole below 60hz. This may be a limitation of the physical design or just the tuning....I'm no expert so I don't know!
I use room correction on my monitors so I'm familiar with the concept but I've never used it with headphones. I'been checking out headphones which go low ( Sony, Audeze etc..) but many receive poor reviews here so I discount them
My question is....can I use EQ to sort out the bottom end on the HD600's, or would I b better off with different headphones albeit with or without EQ? And in either case, what EQ do you recommend and how is it implemented?
Any thoughts would be helpful
Pascal
Pascal
