D
Deleted member 24907
Guest
I got an hd579 which unfortunately is not an improvement over the old hd540 which has died. I miss the airless and being in the bubble effect. You don't know what you miss until it's gone.. Been trying to get an EQ on the laptop but I was unable to get the preferred one used here to work. Realtek might be the issue. I ended up trying Boom which nicely integrates with tidal. I am using reference audio analyser where I compare the frequency response of the hd650 and am adjusting the equaliser to match the differences. Is this the correct approach or should I aim for a general other curve? Other question: will the boom equaliser settings work on new phones usb c out? Where a dac dongle is needed? In this case: will it then also work if I use this phone as source to a headphone amp?
