Ramon Cota
1 . The subjective review
bass : good , neutral
midrange : maybe a bit too lean
treble : maybe a little too bright
solution : ramon mod , with it the balance shifts towards neutral-dark and sounds subjectively better
2 . measurements
a) all measurements were made on a flat baffle rig with uncalibrated behringer ecm8000 microphone.
b) stock hd560s
and the same but with different scaling
c) what is ramon mod? It is a cotton makeup removal pad stuffed inside the headphone pads.
and the measured effect
to be honest im not so sure about the effect on bass . it might be as well because i applied different pressures against the baffle when measuring.
2 . measurements
b) stock hd560s
