Robbo99999
Nice, very good price, totally worth it!They are £99 on Amazon UK (Sold By Amazon ) Possibly until Monday
Yep, that's my EQ but you got Filter #1 wrong. Just put it as a Peak Filter like you have for all the others. Following is a pic of the EQ for interest which would have been pictured in earlier posts (they're all Peak Filters).I'm using the HD560S since mid december and the HD6xx is mainly in the drawer, it's really good and the build quality is much better than my other 500 series which is quite squeaky plastic.
I'm using this profile below (probably it's from @Robbo99999 ) and does not always sound right but maybe just the albums I listened were bad sources, HD560S seems more revealing to me than the HD6xx. I'd thank any adjustment suggestions
Preamp: -6.75 dB
Filter 1: ON LSC Fc 20.0 Hz Gain 4.1 dB Q 0.50
Filter 2: ON PK Fc 160.0 Hz Gain -1.3 dB Q 1.00
Filter 3: ON PK Fc 1173.0 Hz Gain -1.0 dB Q 2.00
Filter 4: ON PK Fc 1813.0 Hz Gain 2.8 dB Q 2.00
Filter 5: ON PK Fc 3320.0 Hz Gain -2.1 dB Q 3.50
Filter 6: ON PK Fc 3870.0 Hz Gain 3.6 dB Q 2.00
Filter 7: ON PK Fc 4520.0 Hz Gain -3.7 dB Q 3.00
Filter 8: ON PK Fc 5280.0 Hz Gain -2.3 dB Q 3.00
Filter 9: ON PK Fc 6800.0 Hz Gain 4.1 dB Q 2.00
Thanks, fixed it. I can only have 8 PK filters that's why it ended up as LS I guess. Which one is ok to leave out? That 1.1 KHz -1 dB filter 3 is the one I left out for now. The low end sounded great with games after the fix, the rumble is there and I didn't notice distortion. I like to test bass with this Gears of War trailer, even the compressed YouTube audio sounds good.Yep, that's my EQ but you got Filter #1 wrong. Just put it as a Peak Filter like you have for all the others.
Hi, given you've got limitation of 8 Peak Filters then I worked out just now what Low Shelf Filter would have a nearly identical effect as the 20Hz Peak Filter I used. So instead for Filter #1 use Low Shelf at 54Hz, +4.1dB at Q0.71. That means that you'll be able to reactivate the 1.1kHz filter.Thanks, fixed it. I can only have 8 PK filters that's why it ended up as LS I guess. Which one is ok to leave out? That 1.1 KHz -1 dB filter 3 is the one I left out for now. The low end sounded great with games after the fix, the rumble is there and I didn't notice distortion. I like to test bass with this Gears of War trailer, even the compressed YouTube audio sounds good.
I'm using this profile since your reply and going through many albums this is clearly improvement and now the sound is full and balanced, even some albums I thought are more compressed have greater dynamic range. No desire currently to use my HD 6xx, this is also comfy and good for everything.Hi, given you've got limitation of 8 Peak Filters then I worked out just now what Low Shelf Filter would have a nearly identical effect as the 20Hz Peak Filter I used. So instead for Filter #1 use Low Shelf at 54Hz, +4.1dB at Q0.71. That means that you'll be able to reactivate the 1.1kHz filter.
Excellent, pleased it's worked out for you!I'm using this profile since your reply and going through many albums this is clearly improvement and now the sound is full and balanced, even some albums I thought are more compressed have greater dynamic range. No desire currently to use my HD 6xx, this is also comfy and good for everything.
Thank you for your EQ!
You've got no labelled scale on the y-axis so we can't really assume what kind of differences we're seeing between the various lines. It's normal for there to be some variance between different units and if you also factor in different people measuring the headphones that's also some extra variance there. I have no idea if for sure all of these people use 5128, and I'm also not sure if there are some different variants of the 5128 that you can get (perhaps not), but for GRAS measurements there are a lot of people measuring using Chinese cloned equipment which is cheaper but doesn't show the same results. It's also possible that some of these people have measured the Old Version of the HD560s rather than the New Version, so that's another point of variance, and there's no information re the degree of pad wear for these measured units - so all in all there's quite a lot of potential variation that could be going on here that doesn't have to be associated with just real unit to unit variation, albeit that will be a factor too.View attachment 419782
What is going on at 7k on some of these 5128 measurements?
The dark blue line is avg of L+R from HypeTheSonics, if you look at their left channel it also drops like this.
One of the light blue or red is RTings and the other is I think Resolve.
Orange is an average of the measurements from Listener, which I don't think includes everything to date.
Green is SoundGuys.
No idea who pink is.
Also a lot of variance at 3k.
Light blue and red also way higher at 15k.
That 7k is a disaster though if some units are like that.
You can not assume all HD560S/400PRO 'measure' exactly the same on a similar fixture under the same circumstances.View attachment 419782
Green is SoundGuys.
Using references, ears, parametric EQ and many years experience.
I am sure you will have tons of objections, if so just ignore me.
I've always thought people talking about cables were crazy, but recently I've found a difference between the stock cable and some cheaply bought balanced replacement cable. I didn't use to believe cables makes a difference either but after a year of using my bal cable going back to stock cable makes it seem so much darker. But now the imaging seems right, I can pinpoint gunshots and footsteps much better in games like CS2 and be able to tell the directionality of audio.Replying to my own post with a small update, in that post I said that my HD560s didn't sound right when I got it back from Oratory, well I managed to fix that, it was the cable. Now I'm not a cable mystic, and my understanding is that they either work or they don't, but I bought a replacement short cable just because I wanted a shorter cable, and it now unexpectedly sounds awesome now & I realise now why the HD560s had been my favourite headphone (and is again now). I don't know what the hell happened with that cable on it's journey overseas, but replacing it transformed the headphone back to how I remember it. Now there is still the small damage to the earpad that I had mentioned, but I don't believe that's affecting the sound....how the hell it was the cable I don't know! I would replace the old cable & do comparisons in the same listening session, but the aftermarket cable is an extremely tight fit on the twisting locking mechanism of the headphone attachment, so much so that I had to try many times to get it seated properly and thought I was gonna have to send it back....so I'm not gonna be removing this cable anymore. To be clear, I'm not a cable mystic, something up with the original cable though that happened during it's time away from me, or perhaps reseating the cable in the headphone is what fixed it rather than the cable itself. Happy to be enjoying the HD560s again anyway, regardless of what the hell is going on!
I was potentially wrong about my channel imbalance points I brought up though, because further testing with different headphones shows I do have natural brief swings in my hearing to the right at 7kHz and to the left at 9kHz, so ignore my channel imbalance comments in that post of mine that I'm quoting. But there was something wrong with the cable somehow that I mentioned in my previous paragraph, which was the reason for my general unhappiness with my HD560s upon receiving it back from Oratory.
That post you quoted of mine was an old one from the beginning of 2022, and I can't remember what the issue was with that unit of HD560s with the stock cable before I changed it to an aftermarket one, so I can't remember the specifics. Generally cables don't make a difference, so you shouldn't chase fancy cables - there might have been something wrong with the stock cable I had or it had somehow got damaged in the post on the way back from Oratory, who knows.....as I said I can't remember the details of what was wrong with it. Don't chase cables though, just use the stock one or a good value quality aftermarket cable, but you don't need anything fancy.I've always thought people talking about cables were crazy, but recently I've found a difference between the stock cable and some cheaply bought balanced replacement cable. I didn't use to believe cables makes a difference either but after a year of using my bal cable going back to stock cable makes it seem so much darker. But now the imaging seems right, I can pinpoint gunshots and footsteps much better in games like CS2 and be able to tell the directionality of audio.
So I'm confused about everything rn, with Balanced everything was much brighter and energetic at the cost of terrible imaging (in games) and smushed soundstage (wide but not separated, everything was smushed together). I still managed to enjoy it with music, sparkled well. But for games it really was terrible.
Currently on unbalanced it seems weird, but maybe it's because I've been used to the messed up sound signature the bal cable provided. I'm not even sure if it's a cable issue or a Qudelix specific issue (I've seen threads about similar complaints with the qudelix). And yes I'm aware these systems aren't actually "balanced" and even the dual DAC functionality of the Qudelix only being engaged in Balanced should only be a negligble difference, certianly not enough to distantiate between SE and B. So wtf is going on?
Geekria is selling cables for HD560s which are much approachable in terms of pricing.Just got a pair of these 560S (an sold my AKG K702 and my Sennheiser HD 6xx). I much prefer the 560S.
Anyway: To use with my Fosi DS2. Does it make sense to add a balanced cable to go into the 4,4 input of the Fosi? Anything better/more than used with the 3,5 input?
Quiet a lot of money compared to the cans itself.
I don't think you need the balanced cable for the HD560s, surely you can get it loud enough with the DS2 without using a balanced cable?Just got a pair of these 560S (an sold my AKG K702 and my Sennheiser HD 6xx). I much prefer the 560S.
