Ramon Cota
These headphones have really good bass and midrange , but treble is a bit spiky and sizzly.
Fortunately there is ramon mod available ( patent pending ) , lets see some measurements first.
( all measurements were made on a flat baffle rig with uncalibrated behringer ecm8000 microphone.)
this is how Sennheiser hd25 measures in the stock form :
and the same but with different scaling :
enter the ramon mod ( prototype )...
as you can see it consists of outer wrapping made from a nice black material , it purpose is to provide nice soft touch to the ear , protect pleather pads from skin oil and provide secondary tuning, but there is more
underneath it is situated a circle cut from cotton makeup removal pad that fits pads openings. It is core tech behind the ramon mod and source of its primary tuning.
and finally the measured effect ( since ramon mod prototype is temporarily permanently senwn on , the comparison was made against another copy of the headphone . Both copies are fairly new )
piercing treble peaks are now reduced , and headphones are joy to listen to.
